Advice Needed Best 4K receiver
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I doubt it very much, the tuner frequency span will be determined by the firmware governing the tuner and demodulator chipset
Broadcom have experimented with capturing frequencies outside the norm with a wideband chipset algorithm, but I believe it is more cable oriented.
If I remember correctly there's a Ferguson Ariva receiver that can tune below the standard range, as well as those signal meters. It's not impossible there are other receivers out there with similar capabilities.
A satellite receiver ?
Some boxes do have a capability (minitourner) but in most cases it is afternarket / GitHub / Linux / kernel fiddling.
Yes a receiver, not a Ferguson but a Revez HDS605:
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
How about 10493H 1500 on 26E? I don't expect anything with an IBU but will be interesting to know if you can input such a frequency :)
Yes it’s let me input 10493H1500
But no signal
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Today changed the inverto ultra black with the following and got 5% more signal
I think signal is more stable on this lnb especially in very weak TPS.
Manikm909
Small'ish Dish Man
Kent, UK
ive got the DUAL version of that, i find it VERY good.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
I wonder if the 4G filter is helping some people because all my IBUs give better results than the Inverto PLL on my dishes :confused
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I think different lnbs gives different results on different receivers/tuners
I also tried technomate lnb & result was bad
Manikm909
Small'ish Dish Man
Kent, UK
thats interesting, i have technomate gold, and its VERY close between that, and IBU, and the Inverto PLL
i think we're talking small margins here, the slightest skew variance, and that could be miscontrued as a bad LNB v a good LNB
Also the 'in and out' adjustment - moving the LNB closer or further away from the dish face. It's why short-neck LNBs aren't worth trying on a standard Channel Master - they can't get close enough to the dish's focal point.
Manikm909
Small'ish Dish Man
Kent, UK
yes - agreed - although when i tested, it wasnt that much difference when pulled away or pushed in, skew made the most difference on 1w - i.e it was a reading difference between 75% and 90% signal depending on the skew.
You may have to adjust the declination (or elevation on a fixed dish) when the LNB in/out position is changed to maximise the signal. This is because the CM LNB holder is not in the perfect position.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Anybody knows what is search mode
Advanced
PID search only active on advanced search mode
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I would open the lid and check which tuner it has, perhaps take pictures of the whole motherboard /other circuits/closeups of the big black chips and post them here.
As you wish
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
