Jaeger smr 1224 adjustment-overhaul-maintenance
C
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
Hello everybody,
Back on an old thread on the restoration of a SMR 1224 (restoration / modification Jaeger 1224 - SatsUK)
Jaeger 1224 restoration/modification - SatsUK
make by RimaNTSS but he does not remember exactly the details of the modifications made 6 years ago.
he said:
"all the gears have been removed to tighten them" how to tighten them ?
the 2 parts with the gears with 4 screws added to tighten the gears
There are also the 2 red Allen screws what are they used for?
I also have the magnetic wheel that I tightened several times, I think there is a little "play" with this magnetic wheel, there is a very slight shift in the number of pulses, it would come from all gears?magnetic wheel.jpg
do I have to dismantle everything to check! (to see pictures) ?"
Thanks to everyone who can give me answers
Cardiff
Trust
Trust
Nijmegen Netherlands
Hello everybody,
the 2 parts with the gears with 4 screws added to tighten the gears Its all about those 4 screws I think , just check they are tight
There are also the 2 red Allen screws what are they used for? Behind those red screws are springs , they put tension on the worm axel to the worm wheel
Dont put to much tension on that wom axel , it can break
They should stick out 1 mm or are even with that block
I also have the magnetic wheel that I tightened several times, I think there is a little "play" with this magnetic wheel, there is a very slight shift in the number of pulses, it would come from all gears?View attachment 131204
I dont think the miscounts is done by the gears , maybe the distance between the reedswitch and the swinging magnetic wheel .
do I have to dismantle everything to check! (to see pictures) ?" If those 4 scews are loose and you can move that motor gear part a little apart from that big main gear , both plastic covers need to be removed
Cardiff
Is this the motor from Rimants ?
C
cardiff
Brittany
France
Thank's for all your precise and complete answers
Yes, this is the SMR 1224 from Rimants , I told him about it because I used the pictures from his thread Apr 6, 2014
Thank you
Cardiff
