OCTAGON SX88 H.265 HEVC HD
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
It will be fine :)
stephan94
Bavaria
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
I'd assume so ..... my Edision Primo drives a DiSEqC motor quite happily ........
Morning 'Lazarus' :Y
¿with your motor are you using USALS or DiSEqC 1.2?
Thanks and be safe. :Y
USALS.
And there's also a DiSEqC switch involved.
SimonE
Gloucestershire, UK
SimonE
Gloucestershire, UK
Thanks once again Stephan94 for continuing to give us firmware updates.
Stephan94
Lots of nice new changes such as Resolution in the info bar and the addition of Picons. However I see they have given us control of Brightness, Contrast and Saturation. Unfortunately, both Brightness and Contrast change the contrast. ie the Brightness control is altering the contrast. Perhaps this is still being worked on and will come right later.
Please feel free to feed my comments back to Octagon.
Thanks SimonE
stephan94
Bavaria
SimonE
In this field everything is a question of personal sensitivity.
For my part I see a difference when I change the brightness or the contrast; the results are different.
For one person it's good, for another person it's bad.
alles 50 -vert.jpgIt's very difficult to judge.
SimonE
Gloucestershire, UK
SimonE
View attachment 117630It's very difficult to judge.
Thanks for taking a look, Stephan. I know different broadcasters have different standards but the way I've always got round the problem here is by turning the brightness up on my TV but that makes all other inputs to the TV wrong. When the brightness is set correctly you will be able to see detail in the girls dark hair and the man's jacket without the whites burning out.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Thanks for taking a look, Stephan. I know different broadcasters have different standards but the way I've always got around the problem here is by turning the brightness up on my TV but that makes all other inputs to the TV wrong. When the brightness is set correctly you will be able to see detail in the girls dark hair and the man's jacket without the whites burning out.
Check to see if your TV has an auto contrast option. It's not for TV setting purists but it will mean that the TV can adapt the picture from scene to scene. I have it switched on myself.
stephan94
Bavaria
In the last SW (10462) it is written that now channel picons for Astra and Turksat can be seen.
One must only activate in menu / OSD setting / channel logo.
In fact, for the people who like something, it works.
But you have to make a channel search on all transponders of the Satellite beforehand, if you do not do it the picons will not appear, only then you will see them.
stephan94
Bavaria
Be careful ,
I just learned that there is room only for 2000 Picons in the memory of the SX88.
so it can go very quickly to fill the memory.
For fun I created the folder for Eutelsat 16A Picons,
it works.
Tururu
Assembled with recycled parts
Recycled as the owner.
The picon are cool, but better not to put as crazy, I only have the channels that I use most, on the PC about 200mb to search, apart from the ones I think new.
Los picon estan chulos, pero mejor no poner como locos, solo tengo los canales que mas uso, en el PC unos 200mb para buscar, aparte de los que creo nuevos.
wrong thread deleted :confused
mikeisyou
Feed Hunter
England
The latest update includes support for Abertis TDT (30.0w) exciting times, has anyone had a chance to test it yet? I may have a go tomorrow.
Laser
Not had any luck on Albertis. Nothing downloads
mikeisyou
Feed Hunter
England
I have installed the latest software and scanned 30w but the scan gets stuck at 35 tv channels and goes funny presumably because its trying to scan Abertis. I have been told theres an additional key file you need to run but even with that it still doesn't work.
how to set record time shift external hdd ?
