OCTAGON SX88 H.265 HEVC HD
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
roym
echostar3000ivap channelmaster 1.3
uk
Have a question is it possible to insert keys for Tandberg on 1.9e with sx88. thank you
No. Tandberg is a secure encryption. It requires pro grade Tandberg receivers to decrypt it.
Please do not ask about this topic again (or anything else to do with opening encrypted channels)
roym
uk
ok apologies for that understood.
Posted the following in the wrong place yesterday (and still having the same issues!)::-doh
I seem to have a funny recording-relation issue with fundamental differences between the SX88 (in our "office" ) and the SX88+ (in the lounge) and using the same FAT32-formatted 1TB HDD USB drive. (I used MiniTool Partition Wizard Free to format the whole drive as FAT32)
The SX88 will record to the HDD and replay from it, and when I look at the PVR option in the Menus, I see 6 separate lines:
- Record the browser
- Home network/USB
- Timers list
- Storage
- PVR Settings
- Network shares settings
OTOH, the SX88+ won't record, and all I see in the PVR option are:
- Home network/USB
- Storage
So, three areas of settings are completely missing on the 88+, and that caused, amongst other things, a specific issue because, everytime I tried to set a recording, I got a message saying that that conflicted with an existing Timer setting - and yet I can't find the Timer List on this box to delete the conflicting one(s)!
Anyway, the issues with the 88+ are very repeatable, and both Rx have their latest f/w loaded (I reloaded the 88+ f/w yesterday afternoon), and now I don't know what to try next - does anyone have any thoughts/ideas/suggestions?
Thanks in advance.
Update:
Posted the same issue on Octagon Forums and the Support Guy sent me updated f/w files for both boxes:
- octagon_sx88_plus_v1.04.83_20190107.mupg for the SX88+
- octagon_sx88_v1.04.83_20190107.mupg for the SX88
Only updated the SX88 so far - and can see little, if any differences to the main functions.
Will update the SX88+ later this evening (in hope rather than expectation!)
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
According to my little experience could be the use of same settings on different machine.
Regards
Regards
AFAIK, the only thing that I copied from the 88 to the 88+ was the User database of channels, and, surely, they aren't that different in f/w and setup requirements?
Updatee:
Just updated the SX88+ - the 3 previously-missing lines in the PVR options are now present, and it's now recording a channel on 16E as a test:)
Many thanks, Octagon Support:Y
Updatee:
As I reported on Octagon forums earlier, the SX88 now records, but I can't stop recordings manually!
http://www.octagon-germany.eu/
Firmware (Software) Update V10486 11-03-2019
OCTAGON:
SX88
SX88+ Plus
SX888 IP
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
Changes:
  • EDEM TV added.
  • OTT Support added.
  • DD+ (AC3+) issue fixed.
  • Stalker Timeshift Archive added.
  • DVB-T2 5Volt issue fixed.
  • DVB-C Blindscan added.
  • DVB-C NIT Scan added.
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
Firmware (Software) Update V10487 20-03-2019
OCTAGON:
SX88
SX88+ Plus
SX888 IP
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
Changes:
- Channel Edit Manager improved.
- Signal % Level & Quality Bar improved.
- Mediaplayer Update
- M3u Player Update
- Stalker OSD UI New Design
- EDEM TV added.
- OTT Support added.
- DD+ (AC3+) issue fixed.
- Stalker Timeshift Archive added.
- DVB-T2 5Volt issue fixed.
- DVB-C Blindscan added.
- DVB-C NIT Scan added.
- WebTV Update
Online güncelleyin!
