uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
FC GD
Antenna: SelfSat H50D4
Pay Tv: Allente, Telia
Stockholm
Telstar 12 Vantage - 15° West:
BBC Satback Package Launched on 11043V 44103 Encoded
this is a copy of 27.5°W 11495 V 44100
(info Satfeeds-DX)
wow, i hope that it is on North Sea beam which is much stronger and better. ill give a try
Michal Norek
Czech Republic , South Bohemia
Satellite dish 1m 28,2E, IBU twin, DM 800 SE and Amstrad DXR890
Czech Republic
Hello
i tried this TP in Central Europe with OP85cm but without signal.
If it still broadcasts something there it looks like Euro spot 1 beam focused to UK.
The new signal is there on Telstar - Im getting a very strong signal. Cant decode anything on it though
Joolz
1m Astro 55°E - 63°W
Can I ask some of you friendly pals to help me configure TSReader & VLC to play this correctly?
When I click Playback > VLC > Play, I get this error:
I right click and save payload. Then open file with VLC. It will play at the same time as the file is written.
FC GD
Stockholm
Hello
Perfect, with North Sea beam i meant Euro spot 1.
Thanks for the info!
Adam792
Cheltenham
The 11043 V 44100 transponder on Telstat 15°W looks to be in the same format as 11495 V on 27.5°W.
Encrypted, but the PMTs aren't at the moment (this is usually what hides these) - so the service list may load when tuned with a normal decoder without modification. I will try it out.
Satfaca
Melmac (46N, 14.5E)
Melmac
I have this problem ... I cannot find where the file is being saved to?!
Is there any default location?
FC GD
Stockholm
It is under settings-> ip/dvb settings
@Satfaca
Unfortunately, with your TSReader version, I don't think it will work, only the newer ones, from 55a upwards.
And yet, you can see these streams by watching the how-to video I posted here #14
dvdfilm
1.5m dish
spain
(info Satfeeds-DX)
Are there reception reports from Spain?
dvdfilm
1.5m dish
spain
(info Satfeeds-DX)
Satfaca
Melmac (46N, 14.5E)
Melmac
maxi_power
120cm motorised dishes
PT
Very interesting, I can capture it from the south of Portugal. Weak signal 35%.
dvdfilm
1.5m dish
spain
can you watch the channels?
maxi_power
PT
Anything.
On TV channels I only get epg, but I don't know if it's from the epgimport plugin that I have configured for 27.5W.
In my area, there is no signal at all on 11043 V at 15.0W :(
It appears to be on the North Sea 56 beam(?). The signal covers the exact area of northern England the operator was targeting.
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
The channels can be viewed without any problem. They use a different key compared to Intelsat 27.5º W.
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
in some part of Spain adios amigos you would need a bigger dish at least, i can guess the move from BBC-SATBACK soon they will drop intelsat for this bird, i can already see big Ko`s in the Canaries about this
