Upper band Ka reception
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks Llew ..
Looks like I was right then about the waveguide diameter being around 10mm inside diameter..
Much the same as the inverto in this regard..
Is that a thin stepdown just inside the first ring > waveguide ? about a cm down the throat ?
the 2mm thick rings are a surprise as the invertos are only 1mm ..
Cheers for the dimensions Llew ...
I may well attempt something at a later date.
rgds
VS
I can't see any obvious change in contour from the first ring to the waveguide VS, just some discolouration there. Looking at the Inverto feed, it's certainly a more basic design. Nevertheless, it does its job efficiently enough on my Triaxe dishes.
7E Ka test of the Triax feedhorn on the Triax TD88. Very good S/N values, certainly compares favourably with the Inverto feedhorn.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Now this has come as a surprise ..
I'm currently getting nothing at all from 7East on the XMW..(F15)
As far as I can see ...nothing has moved and 16E is as good as ever ..
Has there perhaps been an outage at 7East ..or they have dropped the signal levels ??
can you check Llew or is the XMW not installed atm
Just doing a crazyscan ...but looks very different ..
perhaps they've had a cghannel shuffle..
fingers crossed..
rgds
VS
In the house tonight VS - can't let that one out under the moon. I'll try first thing.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Yep Azam looks to now be around 21676
Muvi mux and TPA now back..
curiouser and curiouser..
Also ..keep an eye on 21584 approx ..
carrier there atm ..
possibly modulated but out of range for me ..but I'm monitoring.
rgds
Yes, some carrier movements there. There's often empty carriers this time of day, will try later.
Another new African channel VS. Sikka TV. Unfortunate name :eek:
16E 21569H
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
16E 21569H
Not quite getting the 9db you are Llew ..
7.6db (unlocked) ..to 8.2db (locked)
so variable at best ..
I'm already Sikka these variations ...
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
TPA on Eutelsat 7E
Was 21501 H 2441 ...
now moved to 21540H same SR/FEC
rgds
VS
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
Eutelsat 16A @ 16E
21564 H, SR 128, FEC 3/4, ONID 1, TID 1, DVB-S, QPSK - Radio IMMAC, SID 1000, A 101 French, clear
Reception by Peon
No chance with that SR on my TBS5925. Peon's using the not-yet-generally-available TBS6983. Lucky Peon :rolleyes:
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Not a hint here with the TBS 6925....
Din't really have a hope
lol
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So..any news on this new pice of hardware ?
Release date..
availability..
price etc
certainly not much info out there in webland..
all I can find is this :-
The model name is TBS 6983, it's
next-generation very powerful DVB-S2 hardware - it has Dual tuner and
each of those tuners can receive even 16APSK VCM Eumetsat service - for
example previous (old generation) DVB-S2 hardware, even if it's Dual
tuner it needs to switch and be used as Single tuner for 16APSK VCM.
there are no such limitations with TBS 6983. if i need to give more
exact technical specifications:
* if it's used as Single tuner, it can receive:
- QPSK up to 135Msps (yes, that's correct, usually maximum of QPSK used
in practice is 45Msps, but our new hardware is that powerful)
- 8PSK up to 90Msps
- 16APSK up to 67.5Msps (over twice as much as Eumetsat new VCM service)
- 32APKS up to 54Msps
* if it's used as Dual tuner, it can receive basically half of the
values for Single tuner mode:
- QPSK up to 67.5Msps
- 8PSK up to 45Msps
- 16APSK up to 33.75Msps (still enough to handle Eumetsat new VCM service)
- 32APKS up to 27Msps
all advanced DVB-S2 features like Input Stream ID (ISI), ACM/VCM
TI capability by any chance?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Big changes at 7E to muvi mux ..
Same frequency but now SR9600 fec 5/6
Many more channels added ..
at the moment fta ..but I suspect to be encrypted soon..
lineup now
Muvi TV
Muvi Africa Unite
Muvi Nyimbo
Muvi Muviz
Muvi Education
Muvi Prism Africa
Muvi Nkani News
Muvi Combo
Muvi Yanga
Muvi Bakadoli
Muvi Emmanuel
Muvi Novela
and Radio Komboni FM
pics to follow..
Hopefully
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Blank screen currently Nikani News
All other channels showing a picture or promo..
rgds
VS
Yup, got those VS. Confirm Nikani News blank, but not encrypted according to TS Reader.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
SR changed again ..and a new channel in the mux..
Muvi Fire TV ..
Looks like a music channel atm ..but a little confusing cos it gives the impression it's a 'god channel'
and Nkani news new active ..
Education channel appears to have gone ..
New SR = 8986
rgds
VS
Can't lock the Muvi mux VS, over 8dB but no show. Only TPA. Very overcast here. Didn't realise Azam had left.
