Upper band Ka reception
16E - New channel - Eden TV
21541H SR 1070 FEC 3/4 DVB-S2 8PSK
Educational, French audio.
... just as a matter of interest VS / Llew, after paying for your XMW how long after was it before you were sent a tracking number. T.I.A
Had to check my emails from jin, memory doesn't stretch back that far John.
Order placed 27-06-13
Tracking number sent 05 -07-13
Received around 10 days later I think.
Thanks Llew, Jin replied on the 14th Jan that tracking number would be sent soon so looking at your order details my tracker could be with me in a day or so's time. I can't progress with the servo motor for polarisation project until i physically have the feed & lnb in my hands. I'm just eager to get cracking Llew :)
OK John, have to say all TP's are horizontally polarised on D Band on 5E, 7E and 16E (ignore my last screengrabs, I forgot to change to H in Crazyscan)
It will be interesting to see your servo setup when you get it up and working :)
No problem Llew, as you say all documented band D stuff seems to be Horizontal , but i was took in by the V/R indication on your Crazyscan plots for 4.8E :D.
I love a challenge, so to tinker and play with some kind of polarizer gadget might come in use for future sats that might use both polarities one day ?? , we'll see .
As i type Llew, Jin has just email informed me that the units will ship either today or tomorrow.
.... forgot to mention in last post, because my Ka dish is at high level it's not easy to keep getting the ladders out to faff about with lnb, so having some sort of rotatation control will ease the situation.... also, give me some control to adjust skew a tad depending what sat i'm looking at.
That's reason enough John.
BTW, delivery of said XMW may not be quite as extended as I said. I think after tracking email, it was about a week, or less.
Globecast feeds, both BISS_E. E257 Main likely to be Africa Cup too.
21685H and 21667H. Both SR 14397 FEC 3/5 8PSK.
As above, AFCON on 7E Ka 21684H, BISS feed.
16E. Canal 2 now at 21576H 4199 3/4. Was on 21553H.
7E. TPA International now at 21570H 2441 2/3. Was at 21540H.
7E (0PSK?) data carrier with a very low SR, 255 kc/s.
Ok, doesn't lock so can't read any info from it.
uhf-satcom.com
Poole, Dorset, UK
www.uhf-satcom.com
UHF to Ka coverage; 1.1MKu 60E-50W , 1.5M L-Band 15W, 1.8M & 2.4M prime movers.
Dorset, UK
Evening all,
If you bypass the bandpass filters in an Saorsat LNB, keeping the LO at 21.200G that would give you existing 20250 to 19450 coverage with high side mixing, and 22150 to 22950 with low side mixing. Disadvantages will include image noise due to the removal of the BPF, but just for a test its probably worth a try. ( I have a modified Inverto here with external LO input for exactly these tests). The IF stages of the Inverto's are pretty good, and provide gain from about 600MHz to over 2.5GHz.
For polarisation, due to the use of the septum transformer, if you drill that out, you are left with dual linear polarity, you would have to physically move one probe round the board by 90 degrees, possible but probably messy. For experimentation, you can use the typical 1/4 wave depolariser slab in the waveguide.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So is Burkina on 16E just a feed or has it been there a while ?
21563H 1249
rgds
VS
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hi VS,
congratulation! I tried this several times...
Only "NO LOCKED" here with DRO LNB and signal gone again.
First time I noticed 21563 H 1249 was on 28.03.15, according to "KA Band satellites in Europe" list.
Best Regards
qwer
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks Edgar ..
Think it may have gone again ..
tried to lock it on the F15 ..
Nothing yet ,,,so will go back to the TBS card and try again
rgds
VS
Looks to still be there but below lock now at 5.1db
An odd one that. I had it as 'No Locked' before it dropped out a few minutes ago. Clicking on it when it was active gave me a perfect QPSK constellation at 10.3 dB, but it didn't show parameters.
