Bread Making Newbie
Bread, cheese or tonsils?
Great name for your first Novel, P.
How do you know I'm an already published author?
Nah, just joshing. Of course I'm not. But you're right abut the title. Maybe the muse will visit overnight?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
This has to be a first for me ..
Taking pictures of a loaf ..
lol
but as requested ..
Excellent!
Not too dissimilar from my own two recently posted examples.
Nice one, Nelson.
(When I say Posted, I meant the piccies, not the Bread. I'm not in the business of feeding delivery personnel)
Ghostleader
Glasgow,ish!
Guys can you make cakes, maderia, fruit loaf ect in bread machines? Many thanks in advance.
Sent from my thl_T7 using Tapatalk
Jesus made bread and wine using two ingredients, but things have progressed in 2000 years or so. I welcome the idea a bread making machine can be used to ferment something worth imbibing in an hour or two with the right catalyst.
....... Allegedly
battenfan
1.2m pf
60N 18E
Today I reheated a danish on the lid of a tin can, on top of a toaster and a small bowl placed upside-down on top of it.
Mini oven.
Archive7
Bread machines have a dough making option and also cake option. You can add fruit in the second dough stage for exanple.
You can use the dough option and then bake in a standard oven. I think the result would be better this way than to rely solely on the bread machine.
If you already have the facilities to make cakes, it might be pointless to invest in a bread machine, as these things take up valuable space in the kitchen.
Most bread machines makers give recipes.
Please check the attached file for recipes, not necessarily only for this machine model.
  • Cuisinart Recipe Booklet cbk-100_recipe.pdf
Unfortunately this gives recipes using the American "cup" measuring system. Most British (and possibly European) people are more familiar with weighing the ingredients.
Archive7
Thanks for pointing this out.
I found a recipe book from same manufacturer, from the UK distributor or maker?
  • Cuisinart CBK250U_RECIPE_BOOK.zip
Archive4
Does that work for " cup cakes " ?
2cvbloke
Near Pontop Pike, Co. Durham
Just randomly browsing in a bored fashion, but, I was once given the advice that if you use an actual cup (aka drinking vessel such as a teacup or a coffee mug), then the cups measures in US recipes should work out fine as long as you use that specific size cup through the entire process... :)
That or buy some US measuring cups off ebay, they're pretty cheap.... :)
The standard measuring units over here being a cup, half a cup, half an egg, tablespoon, teaspoon and 'pinch'.
The 'knob' could be from either side of the pond.
So, any Bread-making news?
Still producing an average of 3*400g loaves a week with my trusty Panasonic - generally one plain white, one white with seed and grain, and a brownish jobbie.
Fitted a new blade to mine as it got far too loose on the drive shaft (Although they are supposed to have a bit of play in them) but as it wasn't an OEM blade but a cheapie from eBay, I had a slight issue: The end of the blade scraped ever so lightly along the bottom of the pan and looked as if with repeated use it could damage the non-stick coating.
I found the ideal shim was one of those triangular split connectors that fasten the basin chain to the plug. Fitted nice and tight over the shaft so it wouldn't shake loose, but not so tight I couldn't prise it off easily to clean. And it raised the blade just enough to solve the problem.
....... I'll resist the tight over the shaft jokes but was wondering this ---- when you lift the mix container out has your Panny got any corrosion holes around the rear end lol, ours has . It's about 4 years old now but still going strong with loaf output at three a week.
I'll resist the corrosion holes over the rear end jokes and confirm my machine is pristine :)
I have reluctantly passed bread making duties over to my wife as I don't seem to be able knead the dough properly - probably the arthritis in my hands getting worse.
It's been a few weeks since our last home-made loaf (before Christmas in fact) but she has promised to make loaf today. :D
