Amos 7 (was Asiasat 8) 4W
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I've got 328 services found. Should the satellites.xml file be adjusted to this satellite?
nelson_b
Contributor
I locked this a while ago, I presumed the listing was a mistake and it was in the CEE beam ?
That would certainly make more sense ... B.m.
did you lock .. 11052 H 8518 (much weaker) i,v been around home all today so i left the setup on this one .. got a brief lock this morning enough to scan the channels but had no lock since ....
blademedia
Sky
I can only recall locking one transponder nelson, it was a day I was tweaking the dish and checking signal levels. I will take another look when its a clear day
Archive7
I did a terrestrial transmission scan today and noticed few channels in Israel have started testing.
Ch 1 HD (Main Israel national channel IBA Ch 1)
Ch 9 (In Russian)
Ch 20
Ch24 (Music)
Ch 30 (In Arabic)
It is highly possible that Ch 1 HD in FTA would start transmitting from Amos 7, hopefully in the near future.
The other channels will continue to be paid channels from Yes and Cable company Hot.
I am getting very good signal from 12288H and 12348H this morning at nearly 9dB! Last week I was unable to lock it at all - not sure if it's permanent or a blip. And it's drizzling here too...
12315H is 7.7dB - which is about the same as it was before.
RimaNTSS
N-E from Riga
This also could be the result of daily movement of the satellite. If you check signal during the day, I am pretty sure, levels will be different. Remember my post #121 in this thread?
Yeah, I'll keep monitoring it throughout the day and see what it's like.
Laser
Still around 8dB here in Berkshire. Just could do with some channels we can watch!
Yes, stable at 9dB here still...
Signal has been going down throughout the afternoon and is struggling to maintain lock but it's drizzling and there's a big black cloud overhead.
pontiend
Contibruter
south yorkshire
This is a surprise I seem to have got a transponder from Amos 7.Please do not bust my bubble and tell me that it is not.:)
12315 H 14998 7/8
TBS6983 100cm Dish.
RimaNTSS
N-E from Riga
Yes, you are right @pontiend . Very unique channel, it has videobitrate <than 400kb/s :eek:
RimaNTSS
N-E from Riga
What's the name of the skin on your enigma 2 box
It is HD Glass 16, I think I use it already 7 or so years. However, just recently found out how to add bitrate info to the interface :-rofl2 .
nelson_b
Contributor
This one has been a struggle to get for me here ... I,m sure i,v reached the limit now with 2.4 c.m. on this sat . .... (please ignore the 5 west position on screenshot)
12315 H 14998 7/8
TBS6983 100cm Dish.
I get this transponder every afternoon with a 100cm it stays visible for a few hours then disappears until the next day :(
Just checked it out & I am now getting a good signal in the morning :)
9:15 am 62% Quality on TM6902HD.
pontiend
Contibruter
south yorkshire
I have scanned 4 West quite often lately.
Hoping to get something.I didn't expect to get anything.
I was surprised to see 12315 H yesterday .
Gone today.I will have another look this afternoon
Below is the scan 6.7 dB 12542 is off 5W
TBS6983 100cm Dish.
12315H comes in most of the time here. 12348H and 12288H are still visible here but a dB down on yesterday at the same time. Have around 1dB margin here but will probably lose it in the afternoon.
Strangely, signal level variations on 12315H are different from 12348H and 12288H, so perhaps daily wobble along with providers playing with power levels?
Locking onto 3 new transponders here:-
TM5502HD + 100cm
