Eutelsat 33e @ 33.1°e
WaferSat
Laminas OFC-1200P, 30w-46e
Southern Finland near Helsinki
31 channels found on this bird, not much more available?
WaferSat
Here is the result (clear before scan activated)
blademedia
Sky
Thanks I wasn't thinking about radio channel's. there's a S2X mux @ 12621 it doesn't look like your card decodes it, feeds turn up quite often.
WaferSat
Here is another scan with a PC-card, about the same result as with an Enigma2 device
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Eutelsat 33E 33.1° East FTA
Are these actually FTA as of now or are you just promoting your YouTube account? I've seen you posted similar in the 1.9E thread (even though the channels are no longer FTA)
Thread title updated from 13C/13D to 13E.
dreamsat
germany
many Data Channels
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
My latest reception
EnoSat
enosat.euweb.cz
Slovakia
    <sat name="Eutelsat33E (33.0E)" flags="2" position="330">
        <transponder frequency="10727130" symbol_rate="44762000" polarization="0" fec_inner="0" system="1" modulation="0"/>
        <transponder frequency="10775080" symbol_rate="34286000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="10795900" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="0"/>
        <transponder frequency="10815080" symbol_rate="30000000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="10834260" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="0"/>
        <transponder frequency="10853440" symbol_rate="30000000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="10872620" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="0"/>
        <transponder frequency="10999000" symbol_rate="10200000" polarization="0" fec_inner="3" system="1" modulation="2"/>
        <transponder frequency="11054410" symbol_rate="34286000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11074000" symbol_rate="11000000" polarization="1" fec_inner="0" system="1" modulation="0"/>
        <transponder frequency="11219250" symbol_rate="31428000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11240000" symbol_rate="31429000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11257610" symbol_rate="31428000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11277000" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- short/mis0 -->
        <transponder frequency="11295970" symbol_rate="31428000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11316000" symbol_rate="27500000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- short/mis0 -->
        <transponder frequency="11334330" symbol_rate="31429000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11355080" symbol_rate="31428500" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11372690" symbol_rate="31428000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11392000" symbol_rate="27500000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- short/mis0 -->
        <transponder frequency="11411050" symbol_rate="30000000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long//mis0 -->
        <transponder frequency="11431800" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- long//mis0 -->
        <transponder frequency="11470160" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11487000" symbol_rate="27500000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- short/mis0 -->
        <transponder frequency="11526130" symbol_rate="30000000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="11542380" symbol_rate="21818000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="12587060" symbol_rate="8333000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- long/single -->
        <transponder frequency="12616000" symbol_rate="30000000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="12646000" symbol_rate="13917000" polarization="0" fec_inner="3" system="1" modulation="1" pls_mode="1" pls_code="210115" is_id="3"/>
        <transponder frequency="12673280" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
        <transponder frequency="12692460" symbol_rate="30000000" polarization="0" fec_inner="0" system="1" modulation="0"/><!-- long/mis0 -->
    </sat>
