Amos 7 (was Asiasat 8) 4W
The feed 12392 H 3200 id=ROU-TELE-M had switched off when the 30 sec scan was completed.
pontiend
Contibruter
south yorkshire
12315 H 14998 7/8 is back. 57%
Time for a scan maybe something else has turn up:)
Edit nope only 12315H
TBS6983 100cm Dish.
Haven't checked the Amos spot for some time. Here's my finds. Only FTA I can see in the higher F's is 12315H, no feed at present on 12392H.
Some 5W in there, apologies.
Is that on the Gibby, Llew? Impressive as these figures are more or less identical to what I get on the 1.8m!
5W removed (schoolboy error, tut tut)
Yes, Gibby 1.2 CJ. I usually do well with the Amos's because of my location.
DSCN1928[1].JPG All signals still up on the Amos-7 European beam as this was not possible a couple of weeks ago maybe to quote:-
avi_s@amos-spacecom.com reply to me a few weeks back about Amos-3
"Will , the antenna on board is not steerable therefore the satellite itself has to be re-pointed … as most of our customers are located within CEE I don’t think this will be supported by our marketing team"
So Amos-7 satellite may have been re-pointed or the power increased otherwise we would not be able to receive it so maybe after a re-think Amos-3 may be re-pointed in the future ?
I was getting 80% signal quality this morning with the 100cm on 11590 H DVB-S/MPEG-2 3700 3/4 TVH
Then the opera de paris feed fired up on 11592 H 14400 S2 HD & completely wiped out TVH on 4 west,
I did try nudging the dish further east 3.7 west but to no avail,
I would have thought that by now that spacecom & France TV had an active frequency plan for 4 west & 5 west :-doh
It is not a new feed MET Opera also use this frequency.
OK here at present William, but needed dish better aligned to quieten the Opera feed.
1.2 Gibby.
Also OK here but stronger signal slightly away from 3.8W - probably around 3.5 - 11dB on 1.8m. It also comes in at 5dB from 3W!
nelson_b
Contributor
This channel is officially on frequency 11,630V 3000 2/3
Could this be a feed?
Amos 2/3/7 at 4.0°W - LyngSat
Hi- HB13DISH16
I took my Transponder info from Flysat ... they only list the channel at 11067 H 3000 2/3 ..
I see Lyngsat is listing it at both frequencies ? .... 11630 has no signal at all for me here ..
regards ....
pontiend
Contibruter
south yorkshire
Things are looking up here.
Got two more tonight.Now have.
12287H 29996 8PSK 2/3
12314H 14998 7/8
12347H 29996 7/8
TBS6983 100cm Dish.
They must have definitely upped the power in this bird. Maybe William's email did the trick?
SatSearcher
West Yorkshire
Yes definitely stronger, been trying to lock these over the past couple of weeks with no luck, but finally got them tonight.
VodzigorLans
Setup is down atm
RU, Saint Petersburg
New tp is activated today. Test you signal quality. Data from stream is NIT: 4.0W 12.411 GHz Horizontal 20833 7/8 QPSK, DVB-S
PMT PID 4112 (0x1010) - Program 1 1ZAHID
PMT PID 4128 (0x1020) - Program 2 Vozrogdenie TV
PMT PID 4144 (0x1030) - Program 3 Ethno_ua
PMT PID 4160 (0x1040) - Program 4 BOUTIQUE TV
PMT PID 4176 (0x1050) - Program 5 4P_INFO
PMT PID 4208 (0x1070) - Program 7 MALYATKO TV
PMT PID 4224 (0x1080) - Program 8 Televsesvit
PMT PID 4240 (0x1090) - Program 9 GALYCHYNA
PMT PID 4368 (0x1110) - Program 11 1+1
Signal is fine but a bit lower than others here.
Fanciu1983
C-band Hawaii 2.4m
Hawaii
can you see at the moment any active feed on Amos-7 in the 11.45-11.7 GHz, horizontal pol, pan-european Ku-band? Can you please provide central frequency and symbol rate ?
dreamsat
germany
here is a feed at 11068 H 3300 5/6 QPSK
