Just Sharing This TM5402HD Ch list by William-1
Hello William
My tuner is Technomate TM-5402 HD M3CI, I'm from Poland. I sincerely ask you for a 2017 channel list from 60 East to 45 West because on polish forums I couldn't get any help. I would be grateful if you could help me.
Welcome to Satellites .co .UK mizielin
You can load my latest list then add the satellites passed 53 east as I cannot receive them here due to obstructions.
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
Hello William
go to the purplesat website, they have a good channel list
Why would anybody want to use that website - its HORRIBLE to look at and navigate round.
And there is a major typo on the front page of their website.....
John Pykett
Persona non grata
to be honest i have used the website, i dont see anything wrong with it.
sonnetpete
wordpress.com
Normandy, France
John Pykett
Persona non grata
sonnetpete
wordpress.com
Normandy, France
The colours clash horribly & there is too much info squashed into one page. The whole lot needs taking down and redesigning from scratch - the current site looks like its been designed by a 10 year old who know how to use the colour palettes in MS Paint
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Does anyone have a link to a channel editor or an NDF editor? (Linux or Windows)
I want to try and create my own lists for my Dr HD D15 which is playing up.
mizielin
57 South - 45 West
Poland
Btw. - Is CNDF channel list file compatibile with Technomate TM-5402 HD M3CI?
Regards,
Mizielin
Regards,
Mizielin
Yes all NDF files are compatible with the TM5402HD M3
The ndf file extension is associated with the NDFEdit, a TV channel data editing program, developed by ClarkeTech company.
The ndf file contains channel data from set-top boxes (TV, satellite).
The NDF Channel list made using the Clarke Tech Editor Studio is then called a CNDF channel list file for Clarke Tech satellite receivers,
On Technomate satellite receivers the correct term is an NDF file,
Other satellite receivers or clones of Hubtech such as Strong, Dr HD, Blade ect use the NDF file system.
@william-1
I have downloaded your latest channel list, and the NDF editor - many thanks for those.
However I have a question about the downloading of the NDF file onto the TM5402 M3, i.e. when I select the channels file to download from the USB stick to the Rx, I am given a choice of selecting the Default DB (database?) or the Normal Database.
Can you tell me what the difference is between the two, and which one I should chose?
Thanks in advance
Use Normal Data Base that is what I do.
The Default Data Base is the original that was loaded into the receiver several millennium & is out of date.
Many thanks :D
Technomate TM5402HD Channel List by William-1
November 2017 all satellite transponders updated 53 east to 30 west
For more channels just re-scan any satellite.
This channel list is suitable for all single tuner satellite receivers using the NDF file system:-
TM5402HD M1,M2,M3 & TM6800HD
Blade 7000s, DrHD D15, DrHD F16, + Clarketech & Strong.
  • TM5402HD M1 Ch List by William_1 Nov 2017.zip
John Pykett
Persona non grata
cool but i prefer ********** one.
Technomate TM5402HD European TV & Radio Channel List by William-1
January 4th 2018 all satellite transponders updated 53 east to 36 west
  • TM5402HD Ch List by William_1 for Jan 4th 2018.rar
  • TM5402HD Ch List by William_1 for Jan 4th 2018.zip
@william-1
Having just loaded your latest patch on the TM5402 M3 in our "office", I was finally able to confirm (with the aid of the Flysat lists) that I can get IS14 at 45W - even after all these high winds & gales :D
Many thanks
February 1st 2018 all satellite transponders updated 53 east to 37.5 west
  • TM5402HD Ch List by William_1 (for Feb 1st 2018).rar
  • TM5402HD Ch List by William_1 (for Feb 1st 2018).zip
