MCelliotG
- May 10, 2015
- TBS 5925, Mut@nt HD51, EDISION OSMINI, MABO 130X144, DRAGONSAT DS3000 LED MOTOR, INVERTO BLACK ULTRA TWIN LNB
- Thessaloniki, Greece
This is a problem for the 5W transmission only, the 12.5W transmission has different SIDs as it should.Hi Adam792, do you use E2 box?
TSID is not the input Stream!
Same SID on different Input Stream with same TID and NID, enigma2 don't like that! (file "lamedb")
IS33 DMAX SID=50
IS34 Alpha SID=50
IS34 ibox65 SID=60
IS35 RadioItaliaTV SID=60
IS35 Spike SID=50
IS35 SUPERTENNIS SID = 40
IS36 Deejay TV SID=40
However, this issue is solvable in E2 when the Ignore Subnetwork for DVB-S value is off! Very useful for 5W in many ways....
