Ka-Band Satellites
** 18.703 & 18.669 now locking but very intermittent
123453123454
dreamsat
germany
18737 22500 3/4
18772 22500 3/4
i think it is LHCP
18.633 is also present but very very low.
All the 5 frequencies previously detected by Feedsat_DXer in 2018, were used for data. Info lifted from Satellitescommunity.de thankyou.
123460
.. The low level signal at 18.608 not resolved yet per 's-band' screen grab, so needs checking out - perhaps stronger signal in Europe ?.
123462
19.2° East - Ka H feed.
Part of the horse racing feeds.
18773.8 H. 5498. 4/5. Network: Scopus. - Provider: SNT. ID: Scopus-VARESE SAT.
123482
A little too low for me John, 4dB compared to the others in that area.
123492
dreamsat
germany
I adapted my setup today. Now I can receive five transponders. Everywhere runs "Turksat Tanitim"
regards
stephan94
Bavaria
with a small 1.20 and very bad weather42°0E_18737_H_2515.jpg42°0E_1903141123.jpg42°0E_1903141123_18640-18840 H.jpg
dreamsat
germany
18996 LHCP 6000 3/4 Data
Athena Fidus 37,8 East
s-band
Essex
Can anyone else confirm the data signals from Thor 7 0.65W from 18.6-19.6GHz? Most are LHCP but there are some on RHCP and they are <3MHz wide. They peak at the same point as the beacon on 20198MHz. In teh 2nd plot, red=LH, green=RH.
View attachment 123507View attachment 123508
Scan on Thor 7 @ 0.6°W on that frequency span produced diddly squat Graham - not even the slightest hint of a signal over the whole 18GHz band. Limited to scan polarities though - could only do a Vertical scan on the Norsat PLL and a LHC scan on the Hughes.
**Edit - i did scan either side of the Thor 7 orbital position and still diddly squat. My analyser display was as flat as a pancake , nothing like your trace.
** Double edit - - iv'e scanned from 19° East from where Newsnet is etc through to 15° West on the 18GHz band on V pol and there is nothing here at all once you leave 19°E, will try on the LHC Hughes.
** Treble edit - same result on LHC scan from 19°E through to 15°W - - nothing.
s-band
Essex
Here's RHCP and which shows the data in comparison to the GS etc. The data is only 3-4dB over noise maximum and that is with a video BW of 20-30Hz. The sweeps are 4096 points hence the large plots.
dreamsat
germany
This is what Band A looks like. Nothing to do. RHCP
I'm wondering if it's a footprint coverage thing with me Graham ?? as i live half way up the UK and seeing nothing - you are down at the bottom of the UK and dreamsat1 is even further south and better covered by the Ka footprint ?.
s-band
Essex
Thanks, it looks like you are seeing something, maybe a little stronger than me. i don't think there's much we can get from those signals, even if they were strong.
From my QTH, nothing in Ka band A whatever the polarizatino
and I obtain a different KA Band B scan Result .
CS doesn't see any of the weak signals here. Unless it disappeared between your scan and mine, the only one of yours I can not see is 20110.
Thor 7 0.65W RHCP below:
Here's my scan of Hylas 4 33.5W LHCP
The lower 2 are AOL. There is activity in both polarisations into Band A but nothing resolvable using DVB tools.
dreamsat
germany
Spectrum of AL Yah 1 52,5° East in KA-Band A RHCP
regards
dreamsat
germany
Some transponders are switched off again at 42.0 ° East.
19.2° East - Ka. 18.543 V. 3629. 2/3. BISS. Football / BT Sport HD LIVE.
TOT v AJX.
