- Dec 10, 2004
- 1.2M Channel Master, 1224 motor, VU+ Duo 2
- North West
It will work, providing you have everything set up correctly, starting with the motorized dish.
If setting up the motorized dish, without the Diseqc switch, you run one cable, from the twin LNB, to the motor, then a cable, from the motor to your receiver, either Tuner A, or Tuner B.
You then run the second cable, directly from the LNB, to the other Tuner, on your receiver.
You then set the Tuners up.
When adding a Diseqc switch you simply add it between the cable, from the motor, to the receiver. I'm surprised your motor works, from your diagram, as you have the LNB cable going into the Diseqc switch, then to the motor.
The only problem you might run into, is when recording programs on 28.2E, because if it uses the motorized dish, for the recording, instead of the fixed dish, you will not be able to view other satellites.
