Eutelsat 5 West B
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Аt Black Sea coast - Varna/Bulgaria with 1.2m
128302
128303
128304
128305
128306
duck77
C Band / Ku Band 2.40 PF / Ku Band 0.85 dish for Hispasat
Vu+Duo 4k / Vu+ Zero 4k / Octagon 8008 / Octagon 8008 Mini / Tbs 5927
Satellite reception between 50.0E-99.2W
Azores
Good afternoons with my 2.4 antenna in the azores
in the middle of the Atlantic Ocean before the satellite change I only picked up the following 3 frequencies: 11013 V, 11179 V, 11456 H. After the change, I did not catch these 3 frequencies but I got the following:
12522 V
128308
12585 H
128309
12606 V
128310
12627 H
128311
12669 H
128312
Now marginal in North Yorkshire on 80cm.
Will bung my 1m up when it gets a bit warmer!
Much improved after a quick twiddle.
But the much discussed coding glitch (or whatever it is) remains a pain in the derriere.
Yes most annoying France 2/3/4 ect but 5 & TF1 on the same transponder are fine o_O
Mooncamm
1 metre Gibertini dish, Octagon SX88 Receiver
Lincolnshire
I have that problem with my Octagon SX+. The problem doesn't exist on my Humax 1000FR / Fransat card.
Adam792
Cheltenham
Signal seems to have settled over the day here to being around 1dB C/N less than 5WA was, on the multistreams at least (so 14-15d:cool:. From what you say @Lazarus a bit of tweaking could be worth a go. I've always found those transponders to be very skew sensitive!
Alejandro_V
Channel Master 120 with Inverto PLL LNB
Oslo, Norway
Then maybe I can get them with my 1,8 metre...
Does it require a lot of work for you to test? I would be very grateful if you could check, it could give me an idea of what I need in Oslo and if it's achievable at all...
That must be it your card is decrypting this transmission that my SX88+ & Edision Primo cannot with the current software :eek:
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Do you lock the signal with that quality?
I don't think so.
But another man (with 220 cm dish) from the town of Plovdiv in Bulgaria shows some channels locked here:
Alejandro_V
Oslo, Norway
I don't think so.
Thanks, with very good quality so maybe 220 is not needed...
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
It’s a problem with the stream. France ô and franceinfo have the same problem, That’s because they are on the same stream. France 5 and TF1 are indeed on the same transponder but they are on a different stream. That’s why they don’t have this problem.
Any report turkey and crprus ?
Data123
Golden Interstar Alpha X
65cm
leeds
France 2/3/4 ect now working fine on my Golden Interstar Alpha X
France 2/3/4 also working OK now with the Octagon SX88+ :):Y
Nothing at all on 11509 right now ...... signal was much better in the late afternoon yesterday, so will check again later.
No problem to bung up my 1m dish, though, in due course. Might even reinstate the TD110. There's fun.
Nalleman
Motala Sweden
Sweden
Yes it reguire some work to turn the dish now pointing at 9E but when the weather is a bit warmer and I have a bit more time I might well try it.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
I will check this evening on my Primo. But probably it will be fixed then.
popovp
Varna, Bulgaria
11679V/29950 and 11471H/9900 (84 radio stations pos.91-174 , and TV-VEOA Occasion) can scan, but TVs are scrambled.
11679 - with TV tuner:
128320
128321
11471 - with Ariva 102HD tuner (the same 1.2m dish):
128322
128323
128324
