Advice Needed Strong satellites
At 26E Badr 4 probably. The others unlikely.
42E is an easy catch on a 60cm up here on the west beam. No need at all for a 1m dish.
If you had a 3m dish in the past you should have a pretty good idea of whats possible on different sized dishes ??
Not most - west beam only. No east or Turkish beams - so about half. Personally Ive never had any luck with 7W
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Off course knows a lot about c bands , H and V channels at The same satellite even without changing frequencies (tp now a days as bunch of channels are allocated A same tp ) lnb skew
Even used a metal card insert in feedhorn to separate HC polarisation
I know it’s hard to get a week sat next to strong one as it’s need precision
Dish area comes to play in that kind of situation
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Out of this hobby from long time technology has changed a lot
Not much knows about ku band
But I presume the theory remain the same
Just search amazon uk with gibertini 100. The seller is Gibertini themselves
Always buy direct if you can
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Gibertini 100 XP+
It’s impossible to buy direct and very few available through 3rd parties which can not be trusted for safe delivery and warranty
None through amazon
Back to square one ☹️
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
found one, but its is
GIBERTINI OP100L not Gibertini 100 XP what is the difference £65 plus delivery £9
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
is this dish ok for high winds though its going to be fixed to a 3 feet wooden post then to 3 feet pole
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I get 6 hits searching Gibertini 100.
2 at 85 quid, 3 at 115 - these are the ones with the thicker arms. 1 with no price so is out of stock. All of them have 9 quid delivery
yes found it
it s on amazon sold by hm-sat-shop german seller backed by amazon
E,LN,XP,SE & OP SERIES
hmmm its getting complicated any body help
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
All Gibertini series dishes lnb Collar size is 23 ?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
OP Gibertini 100 XP+ Inverto Black Ultra 0.2
Superior Dark Motor (160° max) or a Stab100 H to H (120° max)
dish you recommended has 23 mm collar but lnb is 40mm
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
It is a mistake. .LNB Collar size is 40 mm..
On the Gibertini website, the 40mm collars are standard, but 23mm collars are listed as optional extras for some dishes.
Gibertini used to supply a separate sleeve in their dish packs to allow multiple collar sizes. Since 40mm has more or less become standard this may no longer be the case.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
All the dish’s on manufacturer website states 23 mm
Unless 40 mm is also included in the box emailed
gibertini
Let’s see what they say
gibertini
You are misinterpreting the website pages because the dish specifications tables ALL show "Feeder Clamp" (AKA "LNB holder" / "LNB Clamp"!) = 40mm, but the 23mm holders are shown in the right hand column of the general descriptions under the heading "Optionals"" - therefore those 23mm holders ARE options!!!:rolleyes:
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Many thanks confusion sorted
23 mm is optional
40 mm is standard
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Ordered it through amazon delivery time is 2 weeks
