- Mar 25, 2005
- Age
- 59
- Primesat/Famaval 1.8 PF C/ku/Ka, Octagon SX8HD1, SX88, Openbox S3 Mini HD-V8S Freesat V7 HD-V8 Finder, Amiko A4K Combo, Satlook Colour HD Spectrum, Sansui A909 Amp and BOSE Acoustimass speakers for the audio.
- Staffs UK
Agree MB. When I had my corotor on the 1.8 with an SMW dual band Ku LNB which had a low and high output and a 9750 and 10600 LOF used in conjunction with a 22KHz switch and the ASC1, the receiver was just set to a Universal setting for Ku it worked perfectly on all bands no problem. The ASC was very versatile in changing the polarity when it detected the relevant voltage from the receiver.The two obvious units that are capable of all motorisation aspects needed are the Titanium ASC1 and the Research Concepts RC2000. The cleanest solution I can think of is to use a Titanium ASC1 for dish motorisation control including skew and the Technomate for scanning/viewing channels.
The Titanium ASC1 is also DiSeqC capable allowing channel selection on the Technomate to automatically move the dish to the correct satellite.
Another solution, ditch the corotor for a bulleye feed with a plate added for C Band using two C band LNBs and an Invacom C120 LNB with the 'Frankenstien' mod done for Ku, no servo motor then needed.
The Echostar could be used as the dish mover and nothing else, and the TM for the reception receiver.
