Advice Needed Best 4K receiver
i think gigablue more quality receiver
need to check how it work hbb and app
not have info about it
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
you cant go wrong with octagon sf8008 - tuner more sensitive than edision mio 4k
for any E2 receiver you can download and use SATFINDER app configured for E2 ip address - i use it up ladder to peak signal in real time over wifi
I got it last year for few days and then returned it problem faced
Freezing, poor picture quality and delay in changing channels.
Manikm909
Small'ish Dish Man
Kent, UK
never had that, i have two of them
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
We've had a few people have problems with 4K televisions (LG & Philips IIRC) and E2 receivers. Perhaps an issue with HDR?
I doubt it is a resolution issue but try 720p if your TV is some three years old or over.
Setting the next one to multi( as opposed to 50/60Hz ) cures a number of issues on reception here.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
i had used with 4k lg tv i think it was octagon software related problem
I hear Amstrad SRD510 is cheap and compatible with all TVs..
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Just got
Xcruiser-XDSR785HDR avant Android 4K
How does the sensitivity compare with your Octagon, have you tried any low symbol rate transponders & does it have blind search?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Octagon is 44% on 12130 on badr4
Xcruiser is 80% on 12130
yes it has blind scan
which low symbol rate you want me to try
A better way to compare sensitivity would be to keep nudging the dish and seeing which receiver's picture starts to break up first. Percentage figures aren't comparable as they mean different things on different receivers.
Try 23.5E 12640V 940 Radio Deutschlandfunk
I would open the lid and check which tuner it has, perhaps take pictures of the whole motherboard /other circuits/closeups of the big black chips and post them here.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Here is the result
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Octagon picture get pixelated 2 nudges before xcruiser on 12130
Assuming you are using an Inverto Black Ultra single, how are the receivers connected, is the Octagon connected to a loop through from the XCruiser or are you swapping the cables over? If you are swapping the cable over that's a decent improvement.
Are you using just one receiver to nudge or on each receiver separately? One receiver's nudge may be bigger than the other's. Do you receive any extra channels on 26E? Also where can you buy this receiver?
How about 23.5E 12642V 280 Radio Osttirol
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Swapping cables
Will soon do blind scan on octagon sx88se and xcruiser XDR785HDR 785 and then report back the result
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Bought it from Dubai 530 AED
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Yes nudges can be of different size on different receivers
Raining outside so no able to observe this
Tried 12642v280 no signal
Whatever the technical specifications of this receiver I must say the picture quality is outstanding and menus are fully functional on Android phone through air sync remote App.
