40.5W SES6 & NSS806
Manikm909
Small'ish Dish Man
Kent, UK
nice one @John - this will help me, when i go back to dual LNB - out of those DATA's which is strongest?
thanks!
rs100
CM 1.0 DISH
Done a quick scan on Ku , all data - Didn't look at Cband.
There is occasionally a feed on 11339 H as well.
Thanks what’s the symbol rate on one of the strong ku transponders thanks
Here's the scan of the data frequencies with more info
frankviana
Satellites/tv
Brazil
Hi.
Updates here:
Package 40,5º W (4095 V 30000) now on 58,0º W (3720 V 30000):
rs100
CM 1.0 DISH
Thanks any idea what those data steams are used for ?
rs100
CM 1.0 DISH
The ku transponders are strong here but no c band signal I’m going to try a new c band lnb with conical feedhorn
Just to clarify - Your profile says 1.0 mtr CM dish - is this still correct and is this what you will use for your C-band signals reception
Manikm909
Small'ish Dish Man
Kent, UK
Is there a euro ku band data transponder on this satellite I can use to find it if not what’s the strongest c band frequency to use to find it ?
i knew i posted it somewhere... post 28
Manikm909
Small'ish Dish Man
Kent, UK
can someone please tell me which TP ` or channel is close in DB to ESPN - on 40.5. im sure FS1 2 and 3 argentina were weaker than ESPN, but i cant get ESPN, but can get FS1 etc.... its doing my nut in
Manikm909
Small'ish Dish Man
Kent, UK
urgh - fox. - i can get that around 9.8 to 10.5 db. -no sign of ESPN
Satfaca
Melmac (46N, 14.5E)
Melmac
Try to play with skew, ESPN is quite sensitive to polarity setting.
nelson_b
Contributor
Hows 3983 R 4332 with you ? ... its 0.2 db weaker than ESPN here with me on 2.4 c.m
And as @Satfaca suggests skew may well be important too especially as 3983 is close in frequency to ESPN but on the other polarity
I think the FEC may possibly have changed for ESPN from 3/4 to 5/6 but not 100% sure about that.
Lyngsat has it at 5/6 and Flysat has it at 3/4
At 3/4 it requires 7.9dB for a lock, at 5/6 it requires 9.4dB for a lock.
If you were locking ESPN previously at somewhere in the 8dB's or lower 9dB's and it was FEC 3/4 but has now gone to FEC of 5/6 that would explain why you have lost it.
Manikm909
Small'ish Dish Man
Kent, UK
CITY TV ?? no problem.
Manikm909
Small'ish Dish Man
Kent, UK
i think ive run out of luck using the CBAND \ KU band adapter. CBAND needs to be BANG on central for me with a 1.8m
nelson_b
Contributor
Its puzzling that you can get ESPN in the central position and not in the above k/u position ? when i experimented here with C above k/u on 1.8 and 2.4 Channel Master offset dishes, with a small amount of fine tuning i was able to get an equal signal strength lock above k/u as when central .... this was not the case with C band to the side of k/u though, there was always some loss with side configuration.
ESPN LHCP is coming up as 21600, 5/6 with me at about 10dB up here in the Midlands but it's touch and go to keep a lock.
Here's a few more LHCP's using 5/6 FEC - all around the 9 to 10 dB area with me.
4071.
3891.
3878.
3872.
3834.
3803.
3763.
Manikm909
Small'ish Dish Man
Kent, UK
thanks guys - your on my xmas booze up list - ive moved onto 55w linear....just pulled in quite a bit.....
will try 58w after....
i need to learn portugese.
