Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
Thanks what’s the symbol rate on one of the strong ku transponders thanksDone a quick scan on Ku , all data - Didn't look at Cband.
There is occasionally a feed on 11339 H as well.
Thanks any idea what those data steams are used for ?Here's the scan of the data frequencies with more info
The ku transponders are strong here but no c band signal I’m going to try a new c band lnb with conical feedhorn
i knew i posted it somewhere... post 28Is there a euro ku band data transponder on this satellite I can use to find it if not what’s the strongest c band frequency to use to find it ?
urgh - fox. - i can get that around 9.8 to 10.5 db. -no sign of ESPN
can someone please tell me which TP ` or channel is close in DB to ESPN - on 40.5. im sure FS1 2 and 3 argentina were weaker than ESPN, but i cant get ESPN, but can get FS1 etc.... its doing my nut in
CITY TV ?? no problem.Hows 3983 R 4332 with you ? ... its 0.2 db weaker than ESPN here with me on 2.4 c.m
And as @Satfaca suggests skew may well be important too especially as 3983 is close in frequency to ESPN but on the other polarity
i think ive run out of luck using the CBAND \ KU band adapter. CBAND needs to be BANG on central for me with a 1.8m
