Ka lnb ?
This Ka band LNB is somehow meant to work with a modification but how ?
You can use it as is for Band A use , L/R circ poloriser left on for any 42East Turksat Circular signals or remove the poloriser and bolt the scalar feed directly to the ODU body for 19.2East Ka Linear pol Newsnet sng feeds, a method of attaching the big lump in the correct position on the feed arms / lnb holder can be challenging. - the mods are usually just stripping it down to recover the receiver board, mod the OMT if you want, change the rx crystal etc etc and you end up with what you see in the previous posts - depends how tech savy you are in doing the mods.
zorrin
Specialised contributor
France
www.facebook.com
france
@John , I think you are making a mistake.
The AN8002 without modification covers the B band from 19.2 to 20.2 GHz.
This is unfortunately the least used part of the Ka band for television.
Sorry, think your right - it was the AN8004 Band D i tested that worked 'as is' :confused
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Erm right well I've no idea what you really mean. I need a how to youtube video for this ! My version is the AN8002 btw
For Ka-Band A the Hughes LNB that most members bought came from the Hughes HN9200 unit and not the AN8002 unit.
The AN8002 unit you have is for Ka-Band B as indicated by @zorrin in post 122 above.
If you want Ka-Band A or Ka-Band D you need a different unit (HN9200 for A, AN8004 for D)
zorrin
France
www.facebook.com
france
As a reminder :
Ka A is normally stated as 18.2 - 19.2 GHz
Ka B is normally stated as 19.2 - 20.2 GHz
Ka C is normally stated as 20.2 - 21.2 GHz
Ka D is normally stated as 21.2 - 22.2 GHz
In the table below you can see the Ka frequencies and satellite polarizations with the type of band:
4.9°E 21579 H - 21634 H - band D
7.0°E 21547H - 21727H - band D
16.0°E 21534 H - 21612 H - band D
19.2°E 18507 V - 18774 H - band A
23.5°E 21575 H - band D
39.0°E 18862 L - band A
42.0°E 18739 L - 18774 L - band A
As you can see, only the A and D bands are used.
With your AN8002 for the moment you have band B
After modification you could have band A
This modification consists of changing the ocilator
And add some dielectric plate somewhere in.
If you haven't understood what I'm talking about, I think it's useless to advise you to look for someone here to do it for you...
If you still have the TBS 6903 connect it up and give it a go..
7mdish
Milan, Italy
As a reminder :
Looking at SMW Ka band LNBs specs, it seems that a fifth range is available: it would be between 17.2 and 18.2 GHz.
I don't know if it was never used or there are plans to implement it.
Also, when band B and C was used in the past?
In general, I suspect that Ka band was so promising some years ago but it is slowly fading now, maybe for too variable signals during rainy or bad weather times. What do you think? Thanks.
zorrin
France
www.facebook.com
france
While looking for an orthomode for linear polarization in Ka band I came across the following document: A Simple Orthomode Transducer for Centimeter to Submillimeter Wavelengths
The orthomode seems to me possible to redo in 3D or in machining but we need the right dimensions.
Is someone strong enough to make the table of corespondence ?
And who is able to redo the orthome if we have the right dimensions ?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
As a reminder :
Ok understand and thanks for explaining but Newsnet will remain a dream it seems unless I can find a band A ka LNB but then my 1m dish won't be big enough ?
You can get Newsnet using an 8002, read what s-band wrote a few years ago:
Your previous posts and profile suggest you have a TBS 6903 card, if so no difficult hardware mods are required. A larger dish may be needed but no harm trying..
Since frequency is inversly proportional to the wavelength any CAD machine would be able to adjust the programme accordingly.
I would assume a 3D model will not efficiently pass millimetre waves though, the finished product in plastic could however create a solid metal item by use of a sandcast.
zorrin
France
www.facebook.com
france
you mean that a cross multiplication is sufficient to go from 78-102 GHz to 18-26.5 GHz?
zorrin
France
www.facebook.com
france
Yes, though you will need to round down the flange sizes to the next available Wr/WG number.
I am surprised at the measurements for the 18-26 waveguide, the ratio is not 2 but 2.47
If I find a CNC machinist not too expensive I would make a piece to see but directly for the fixing of the GILAT lnbs.
For the feedhorn it's another story...
zorrin
France
www.facebook.com
france
No I did not mod the ports (yet)
I called that side port TX port but thats wrong , that port is orignaly closed by a plate .
The TX signal is fed-in through the back of the OMT , that port is 7 x 3 mm .
Both other ports , deep in the wave-guide , are the same , 8 x 2.5mm .
The RX port is going over into 11 x 4.5 mm .
Today I placed the 27.000 Xtal in the AN 8002 and made a blindscan with the LOF 18.250
Found EquTV 19.735 at H and V with 7.9 dB , seems the lnb is in circ mode ( no poplarizer attached)
Maybe caused by the shape of the lnb inlet ? it looks the signal is gonna twisted to the antenna probe .
Since I ruined the first AN 8004 (long time ago) I do have a spare RX body , so I will mod the port to rectangular and see what happens .
For those people wondering where to get the F connectors , I made them from angled types or from broken moteck rotor boards .
@Trust , look at the last page of the document I shared in my post 129.
Doesn't that remind you of anything? :rolleyes:
@s-band had already put his finger on it
I think you should move on with your idea :)
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Just been reading many of the replies which I didn't read at the time, all explained very clearly with great photos etc. I must have lost interest at the time as 2018 is the year my Dad died. Really appreciate the help to those involved
none
Austria
Hi
I dont want create a new tread. I am from and would like explore the KA Band to. My HW is an TBS USB Receiver with all the DVB Glories and my Tablet. Sadly I can only in Summer position my small Sat Dish since I have to open the Window and in Winter when its freezing outside the Natural Gas Delivery Company make only that face: . Since it become Summer soon I thought about get a KA Sat LNB and see if I can receive some open feeds. I come across the "labgear vka2" who sold in Ebay from Irland is that a good choice to start with?
Hi
Nothing wrong with the LNB, do you have a Ka compatible reflector, what size and what do you wish to receive ?
