Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
j-f-k
1,6m prime focus aluminium dish + 0,3dB Invacom KU-Band LNB, 1,8m prime focus mesh dish + 25K C-Band LNB
Lithuania
After scan:
01eb0e2b:03a2:0000
    s 3627000:20580000:2:4:491:2:0:1:1:0:2
0320:01eb0e2b:03a2:0000:100:0:0
3627V SID 0x320
p:DVB-S2 QPSK 3627V 49.1°E,f:40
Still no data:
root@vuduo4k:~# astra --analyze "http://127.0.0.1:8001/1:0:64:320:3a2:0:01eb0e2b:0:0:0"
Dec 11 16:39:55: INFO: Starting Astra SM 0.2
Dec 11 16:39:56: INFO: Bitrate: 0 Kbit/s
Dec 11 16:44:30: ERROR: [http_request 127.0.0.1:8001/1:0:64:320:3a2:0:01eb0e2b:0:0:0] receiving timeout
But noticed that pid? not 4096, but 8174:
0-930:00800:0000:0000:8174 N/A
EnoSat
enosat.euweb.cz
Slovakia
dvbsnoop -s pidscan show 8174 ?
root@mutant51:~# dvbsnoop -s pidscan
dvbsnoop V1.4.56 -- https://github.com/OpenVisionE2/dvbsnoop
Transponder PID-Scan...
PID found:    0 (0x0000)  [SECTION: Program Association Table (PAT)]
PID found:   50 (0x0032)  [SECTION: Program Map Table (PMT)]
PID found: 4096 (0x1000)  [SECTION: Program Association Table (PAT)]
j-f-k
Lithuania
Very strange, even on working channels dvbsnoop shows nothing.. :
root@vuduo4k:~# dvbsnoop -s pidscan
root@vuduo4k:~#
EnoSat
enosat.euweb.cz
Slovakia
maybe must defined device
option pd 9 show used devices
dvbsnoop -s pidscan -demux /dev/dvb/adapter0/demux0 -frontend /dev/dvb/adapter0/frontend0 -pd 9
- tuner 0 demux 0
dvbsnoop -s pidscan -demux /dev/dvb/adapter0/demux0 -frontend /dev/dvb/adapter0/frontend1 -pd 9
- tuner 1 demux 0
dvbsnoop -s pidscan -demux /dev/dvb/adapter0/demux1 -frontend /dev/dvb/adapter0/frontend0 -pd 9
- tuner 0 demux 1
or
dvbsnoop -adapter 0 -s pidscan
- adapter 0 internal tuner
dvbsnoop -adapter 1 -s pidscan
- adapter 1 external tuner
or
dvbsnoop -s feinfo -frontend /dev/dvb/adapter0/frontend0
- status tuner 0
dvbsnoop -s feinfo -frontend /dev/dvb/adapter0/frontend1
- status tuner 1
or transponder real without PIDs, but when tuned, there must be at least PID PAT and PID PMT in pidscan
j-f-k
Lithuania
I found some info that "Pidscan is not supported on Vu+ Zero 4K. Most of the other dvbsnoop commands work on Zero 4K, but not pidscan.".. Mine is Vu+ Duo 4K. What to do?
But managed to get this info from 3627L:
root@vuduo4k:~# dvbsnoop -n 1 0
SECT-Packet: 00000001   PID: 0 (0x0000), Length: 16 (0x0010)
Time received: Sun 2022-12-11  18:52:14.477
  0000:  00 b0 0d 03 a2 d7 00 00  03 20 e1 00 2b 51 cb 38   ......... ..+Q.8
PID:  0 (0x0000)  [= assigned for: ISO 13818-1 Program Association Table (PAT)]
Guess table from table id...
PAT-decoding....
Table_ID: 0 (0x00)  [= Program Association Table (PAT)]
section_syntax_indicator: 1 (0x01)
(fixed): 0 (0x00)
reserved_1: 3 (0x03)
Section_length: 13 (0x000d)
Transport_Stream_ID: 930 (0x03a2)
reserved_2: 3 (0x03)
Version_number: 11 (0x0b)
current_next_indicator: 1 (0x01)  [= valid now]
Section_number: 0 (0x00)
Last_Section_number: 0 (0x00)
    Program_number: 800 (0x0320)
    reserved: 7 (0x07)
    Program_map_PID: 256 (0x0100)
CRC: 726780728 (0x2b51cb38)
j-f-k
Lithuania
Finally got all info on 3627L 49.1E. Very strange output..
  • 3627L_49.1E.txt
EnoSat
enosat.euweb.cz
Slovakia
I don't have any VU here, so I can't verify pidscan :eek:
jerome04
Motorized Dish 30W/52E
Vu+Duo4KSE
France
Hello everyone. I encounter a strange problem on the Dasto T2-Mi on the 33°
With the same files, it works on my sf4008, and not on the Vu+, however astra-sm is indeed active, the parameters seem good and black screen. What can I do ?
Thanks.
EnoSat
enosat.euweb.cz
Slovakia
if same package work on 4008 and not work on VU+ maybe stoped stream , did you change the packet size settings (etc. for Abertis stream) or stream processing settings for iCam?
tvdigest
astra 4.8
ua
hello, I did everything according to the instructions, the bouquet registered with the channels krrt but the channels do not work 12245 astra4.8e t2mi
  • log.txt
jerome04
Vu+Duo4KSE
France
hello
all channels are encrypted on biss...
EnoSat
enosat.euweb.cz
Slovakia
oscam work, problem with astra-sm or stream from astra-sm
mbas68
33E
poreč
hi, has anyone who has dm two or on dm 920 image openatv 6.4 managed to open bosnia channels at 33E percent, i have installed everything that is needed but it does not open, if there is a solution, i would like to know, thank you
Have you read this thread?
There are issues with the Bosnians on 33E on DM receivers atm
Maneto
DM900UHD4KTriple, DM800HDseV2, DM800HDse, DM500HD, Dreambox7000-S, TBS5925USB, Ferguson HF-8900HD,(Fuba DDA110 / motor DG380S Speedy = 60°E-30°W) + Fuba DDA850 + E-85 Maximum + E-85 Gessat + 85 TeleSystem + 80cm Famaval + 60cm = 53°E-30W.
Slovakia, Trenčiansky kraj, Prievidza
lamedb:
transponders
014a2cb4:0190:0000
s 11444000:17500000:0:3:330:2:0:1:2:0:0
end
services
0fa1:014a2cb4:0190:0000:1:0:0
11444H_plp0
p: Dasto Semtel,c:150fff,f:5
end
astra.conf :
--Dasto Semtel 33E
dastosemtel = make_t2mi_decap({
name = "Dasto",
input = "http://localhost:8001/1:0:1:FA1:190:0:14A2CB4:0:0:0",
plp = 0,
pnr = 0,
pid = 4095, .....NO PID = 4096
make_channel({
name= "Dasto",
input = { "t2mi://dastosemtel", },
output = { "http://0.0.0.0:9999/dasto0/11442plp0", },
DM900 + DM920 ... OpenATV 6.4 ... OK
rom2005
VU+Zero + TBS 5925
Czechia
What is T2-MI video PID of channel T2-MI Rostov (40°E) 3979L 5120? PID 4096 = bitrate 0 now.
EnoSat
enosat.euweb.cz
Slovakia
They probably turn off the content if it has 0 mbps
Maneto
They turn off T2-MI Rosii 24 Rostov (40°E) 3979L 5120 3/4, or Radio Rosii Rostov (40°E) 3979L 5120 3/4... ?
