Straightening out a 1.5m Gibertini
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
As you may have saw, Picked up a 1.5m Gibby 'new'. Sadly it has came via Parcelforce through a war zone.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Ive laid it flat today and used some sheet benders and a hammer and have it almost there, the top of the dish rim is still bent a bit but it is laying flat with no wobble and the actual dish looks fine so I think it might be 'ok'.
Im just waiting on a 2nd parcel with the 'hardware' to be able to mount it.
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Who sent you an inappropriately packaged antenna?? I would return this antenna at the same moment - let the seller cover the damage because the antenna is not protected as necessary - or the courier service that took over and delivered the package. The antenna will probably be useful for C band - for Ku unfortunately no, because there is no way to get it to produce the results it should. Unfortunately, alu is sensitive
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Was a seller looking to shift it, so there isn't a replacement to send. But yes I am looking into compensation.
I'll certainly still see how it does on Ku, Who knows maybe I can get lucky.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Once, a friend of mine asked to help him with 1.1m gibertiny dish. I must say that was not so easy task to accomplish. I've made the plywood box for the dish, so it arrived in the good condition (same as it was sent). 1.5m mirror, man, that is something to pack safely. The bottom-line of this, antennas bigger than 1m should not be sent via usual mail services, it is much easier (and cheaper) to buy them online. Edit; I mean, locally.
That can be straightened out, but the paint requires some work
As the recipient you will need to ask the sender for compo claiming, then the courier will be in the driving seat on the packaging unless insured for the full amount against 'any' damage beyond total loss as it was delivered.
SkyWatcher
Comag SL65, Azbox Premium HD+, Azbox Mini Me, Techno mate Tm3000 D, Golden V8
London
At the very least it is now not fit for the purpose for which it was sold. You have my sympathy I have had similar experiences but not with a dish.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
It looks like the dish was laid flat on the deck and a pallet or other heavy cargo was loaded on top of it. Hindsight is a wonderful thing but a label marked “do not lay flat” would have helped. Obviously a wooden frame simply constructed around the dish at a reasonable price was the obvious choice.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Got it up on a temporary stand as Ive ran out of ground stands.
Ive never stringed a dish before so it may be totally wrong but the strings to touch in the middle.
Im still seeing a warp at the very top though that I think Ill need to beat out.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Now pull the vertical cord into both ends of the antenna from the middle and watch if the two cords continue to touch. I had a case where the lower right part of the antenna was deformed.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Because im impatient I threw an LNB on it and actually found I was 28.2e just by luck... how often does that happen haha.
Peaked the dish and LNB skew and Im getting 12.5db on the F1 feed on 28.2 currently.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
My 1.8m is getting 11.9db on that same feed so something must be up with that dish, not a great comparison.
Anyone got a 1.5m or about in the UK and could compare maybe?
Manikm909
Small'ish Dish Man
Kent, UK
his dish? your dish more like
his 1.5m is getting more signal than your 1.8m
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Yeh I meant something is up with my 1.8m, probably just LNB skew
Its sort of apples vs oranges anyway, would be good to see another 1.5m result.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
4 strings and they are all touching as well as they can do stacked like that.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Well the day has went from promising to disapointing.
I've pointed it to 7e because I know my 1.2m Gibby on 7e is peaked and working the best it can.
1.2m - 10.6db
1.5m - 10.5db
So I essentially have a 1.5m dish thats as good as 1.2m right now... I guess that top bend is actually a problem Ill have to solve
1.2m - 10.6db
1.5m - 10.5db...
Theoretically, a 1.2m to a 1.5m should gain you just under 2.0dB ( 1.94dB ).
However, it is only an approximation, always seems to be slightly less increase in practice.
I am guessing you should be somewhere in the region of 12.0dB to 12.2dB with the 1.5m.
For a realistic like for like comparison you need someone reasonably close to you unless the frequency is strong UK wide with hardly any local variances across the UK.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Yeh too many variables I agree. Thank you for the 2db gain info tho, thats a good ballpark.
