Arabsat BADR-8
JHVSat1976
VU+ Duo 2 and Big Bisat
Rotterdam, Netherlands
According Flysat Badr 4 now is empty !
This information is not correct because 4 frequency's is acually still on Badr 4:
12092 V
12111 H
12130 V
12182 H
Over in NL, I have seen impressing change in signal strengh on All Kass channels this week! 12245 Hor.
The same applies to Kuwait transponder 12532 H
I see claims that except for the ones mentioned above, all other Badr4 Emea TP's have now moved to badr8
I am honestly in doubt about this! No change at all where it concers Saoudi TP 12149H nor for 12073 where TV5 has it's channels such as Style. Having said this, both of these frequencies have a bit of interference from 28 and or 23.5 east. But so do the Alkass and Kuwait TP!
ocean04
Vaasa
Western Finland (63N 22E)
Badr4 has been empty one week already. All transponders moved to Badr8 12.12.2023
hugok
Technisat digicorder, Dish 120 cm
East Hungary
Hi ocena04 !
Have you got the NW-Africa and the Central-Asia beam of Badr8?
How many cm is your dish?
ocean04
Vaasa
NW-Africa working fine. Central-Asia nothing here. 300cm
JHVSat1976
No it is not as far as I know, several TP's for sure are on the old one still and need to change parameters too.
What is the official source? Flysat or Lyngsat claims are not a reliable source in this. they just publish what all their correspondents send them.
I am convinced that Arabsat is still gradually doing those transfers from 4 to 8. However, indeed the majority is now already on Badr8,
satelliclub
Eutelsat 5 West B + Eutelsat 9B
Tunisia
2 other frequency have moved to Badr 8:
12092 V and 12130 V
Now 2 only frequency's are still on Badr 4:
12111 H and 12182 H
ocean04
Vaasa
Change is observable here in Finland. Some people are seeing transponders for the first time, Badr4 reception is limited here. 100% sure, move to Badr8 happened already 12.12
satelliclub
Tunisia
Now frequency 12182 H moved to Badr 8 and have modified in 12188 H
SR still to 16200
Now 1 frequency still on Badr 4:
12111 H
SatSearcher
West Yorkshire
There seems to be a lot of confusion over what has moved and what hasn't! From what I can tell, everything has moved except the following:
11938V
11977V
12073H
12111H
12149H
This is purely my opinion and I could be wrong! The above freqs are the the ones I've had no change on, still getting the same signal level as I've had for years, no stronger, no weaker. Maybe they have moved, but they are just weaker than the others from my location, that's possible of course!
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
something's happening right now on 11977V. a couple of the channels have gone off air (MTV Lebanon and One.
could it be that they are changing over now?
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
SR still to 16200
I can confirm that. More then 1 - 1.5 db stronger then before, frequency is the same as before...
Yes it does look like Yemen has moved from Badr-4 to Badr-8
No change in frequency or symbol rate as mentioned earlier in this thread.:eek:
12182 H 16200 52% SQ
Moves confirmed to Badr-8 @ 26°east
BBC News on Badr-8 is at the same signal strength as it was on Badr-4 no change 59% SQ,
Euronews is much stronger 82% now (I am surprised it is not in HD now ?) 100% SQ @ 13°east in HD,
Most Arabic tv & BBC Arabic,France 24 & Sky News (In Arabic) are much stronger now 84% SQ on Badr-8
If you need BBC News HD it is 100% SQ @ 19.2°east :Y
Latest update December 21st 2023 17:45 GMT
Signal Quality Badr-8 @ 26°E 100cm + Edision Primo S2
11919 H = 59%=
11938 V = 66%=
11958 H = 74%=
11977 V = 66%=
11996 H = 79%=
12054 V = 77%=
12073 H = 64%=
12092 V = 56%=
12111 H =56%=
12130 V = 52%=
12149 H = 69%=
12169 V = 64%=
12182 H =44% (16200)=
12226 H =64%=
12245 V = 69%=
12456 H = 33%=
12523 H =77%=
12523 V =74%=
12563 V = 82%=
12643 H =77%=
12683 V =77%=
12730 H =82% (3330)
Badr-8 @ 26°E
22nd Dec 2023 11:00 GMT
TM5402HD M3 + 100cm Gibertini + Inverto Black Ultra
11747 V = 4.9 dB (No pics needs a bigger dish)
11919 H = 8.4
11938 V = 9.9
11958 H = 10.5
11977 V = 11
11996 H = 12.3
12054 V = 12.3
12073 H = 8.5
12092 V = 9
12111 H = 9.6
12130 V = 8
12149 H = 10.7
12169 V = 9
12182 H =8.9 (16200)
12226 H = 9.1
12245 V = 12
12456 H =6.3
12523 H = 12.3
12523 V = 12.1
12563 V = 12.4
12643 H =12.2
12683 V =12.3
12730 H =12.4 (3330)
hatters1976
Satellite dish: 1x 2.40, 1 wave frontier T90 (7e-46e). Octagon, gt media gt combo-v8x. Football and basketball feeeds enthusiast.
GR
In which place you live @william-1 ? 12db ? is massive ...
