signal reception , wind rain , Motor wobble
gdf68
1m dish Digipower SG2100A TM2600 GM twin Lnb, GT media 8uhd, vuo duo, Xtrend 8500. GM SR525HD Nvidia Shield Sport feeds
Liverpool
Got a Technomate motor in the garage, not sure what it is, will have a look in the morning. brand new in box.
Cheers
OK, it's the 2600, metal gear version, you can have it for £60 delivered, assuming you are in england.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Had a check and it's left/right play
I've no idea where? Between tube and motor axis, or is it axis play (but I find it hard to imagine, that that could be only left/right)?
Greetz,
A33
gdf68
Liverpool
Greetz,
A33
I'm no expert nor have much knowledge of these issues, other than the motor tube moves left /right , right left . The centre bolt is as tight as it will go . Differing views on here about up/down , left right play backlash etc.
a33
XSAT410
Rebox RE-9000
The Netherlands
The thing I was hinting at:
When you remove the tube from the axis, by unscrewing the screw that goes through the tube, a square axis appears.
Is the backlash in that axis (so inside the motor)? Or is the fixing between the tube and the axis causing the play?
A33
gdf68
Liverpool
A33
Ok to that I don't know, I never removed the tube just made sure the bolt was tight as , and checked which direction the play was.
gdf68
Liverpool
I never took it down just did it in situ.
If I take it down next time yo check , how can I correct backlash in the axis or the tube/axis
a33
XSAT410
Rebox RE-9000
The Netherlands
The screws 1,2,3 procedure are for motor axis backlash.
Tube vs axis movement: I believe I've seen that problem reported once on the internet, IIRC. It must be filled with something, I guess. As I wrote before: no experience with it myself.
Greetz,
A33
Edit: found it here: Diseqc speling door wind, wie heeft oplossing?
Thanks to @Trust !
(sorry, in dutch! But deeple/translate will be of help, if needed.)
