That mechanical hole digger looks like a useful bit of kit although not sure if it would work so well in this hard ground here.
Anyway, I'm done and it was fun exploring the underworld but I wouldn't want to do it again in a hurry.
I did try the dish on the pole in the hole temporarily and it is just a little too high. I would like to keep it hidden from the street a little more so will try cutting off 10cm or so.
Ah, it just occurred to me - there is, actually, another way of getting your CM 120 a bit lower on the pole:
This is a CM pole mount (non-AzEl mount) for the CM90-120.
Not as nifty as the AzEl pole-cap mount for installation, but actually puts the dish a good 15-20 cm lower on the pole.
And, depending on the elevation of the satellite you're pointing at, you can put it a lot lower on the pole if you want.
It also allows using non-3-inch poles, it's specced for poles between 60 and 75 mm.
(Or you could have two on the same pole... now there's a thought, eh?)
