1.8 Channel Master Dish - C band set up
MilkyBarKid1
2.4 Channel Master Alsat Vbox Superjack Truman Premier Plus Receiver
West Midlands
Ive managed to pic:mad:k up 1.8 Andrews dish. Just wanted to explore if anyone has a good result on cband and 7W horizontals. Also is it best to have a c120 flange LNB and get a feedhorn. Any tips greatly appeciated.
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
Id deffo get a c120 flange LNB and feedhorn.
I tryed a few lnbs on my 1.2 channel master and the feedhorn and c120 flange lnb work better than the rest.
satelliteman
On that size dish, certainly a c120. You may struggle for 7w Horz's in the West Midlands.
MilkyBarKid1
West Midlands
Most Channel Master users recommend C120 flange so thats the way Ill go. Incidentally I contacted a website today regarding a channel master feedhorn and they said it was adjustable. Could anyone confirm the CM feedhorn is adjustable? Another thing for me to consider is the cable to i.e webpro etc as I am going to need a cable run of 40m.Its a big garden and thats the only spot has a clear skyview. I understand that the Inverto LNB's work best on longer cable runs?
remlap
Wales
What LNB is on the dish right now?
satelliteman
40 Mts shouldn't cause you any problems; just make sure you fit good quality f connectors.
MilkyBarKid1
West Midlands
Im arranging for the dish to be picked up on saturday. Im also hoping its got the original polar mount. Apparently it has been motorised but the current owner never set this up hes always had it on 1W. Will feedback after dish is collected regarding modifications to the mount etc. Fingers crossed x.
It's custom made for the dish so their is no need for it to be adjustable. Only thing you can adjust is skew. If you want C-band on that dish on offset LNBs you are going to need to modify the Ku LNB holder support arms. Maybe Nelson can post some pictures of his.
MilkyBarKid1
West Midlands
Thanks Huevos very informative reply always here. You have definetly nailed my plans Ill be running both Ku and C Band so the LNB bracke wil need modification. If our buddy Nelson has some pics of the LNB bracket modification then thats good news. Im too much time thinking about which sensitive receiver to get and cant make my mind up F15 or TM5402. Ill toss the coin tomorrow :)
nelson_b
Contributor
hi -
just got home from holiday -- (long drive ) --
will sort out some pics of the current arrangement by tomorrow night --
as Huevos said the channel master offset feed is fixed - i,v never seen a adjustable version
regards nelson.b.
Costactc
Canada
Why don't you try a c/ku band lnbf?
MilkyBarKid1
West Midlands
Apparently, combined LNBF's dont work so well in UK and apparently they dont have low KU bandwith coverage. Dont know if other users have tested this out?
MilkyBarKid1
West Midlands
I followed this up with a supplier and asked him if he was serious. He was trying to sell me off a Global Invacom adjustable feedhorn as opposed to a 'channel master / andrews feedhorn' lol.
Nice work Nelson :) you also have 1.8m also would like to know if your are still happy with the inverto white as I am looking to get a c120 tflange. Also looks like BCS 421c can be picked up easily in the uk. Now all I need to figure out is getting the right receiver. Hope you had a nice holiday :)
Costactc
Canada
That's true I wasn't thinking. Ku band here in North America only uses 11700-12200 with the exception of several Atlantic sats which I use a universal lnb for.
nelson_b
Contributor
hi --
here are some pics of the current setup -- i,v tried a number of different home made bracket arrangements -- this "meccano" style one is rock solid and easy to adjust or change l.n.b,s -
however you do it the side arm/supports need to be lowered considerably to be well out of the way of the C band feeds
the white inverto is good on this dish -- :)
i,v tried some home made C120 ,s , and i had a black ultra twin conversion on for a while - which "very" marginally out performed it on some frequencies - but its gone weak/faulty so i,v gone back to the white tech - i tried a smart titanium twin also , but the white tech was slightly better across all the weak channels that i tested ---
regards nelson.b.
Retired human
Top notch dish and arrangement. *commences drooling*
wod
yorkshire
Very nice setup nelson, hope the roof is strong to hold that dish up there.
MilkyBarKid1
West Midlands
Your amazing Nelson. Didnt know you could do so much with the 1.8 Arms. Well well try and give it a go in the next few weeks. Should be picking up the dish either tomorrow or Sunday. Ill keep you posted.
MilkyBarKid1
West Midlands
Cheers. Any reason for having mounted 2 C band LNBF's.
nelson_b
Contributor
yes -- one for circular transponders -- with (dielectric) T plate
and one for the H/V linear transponders (no plate needed)
just had one C Band l.n.b. initially - but got sick of going out across the yard and up the ladder to take the plate in and out between sats/channels -- L.O.L. :)
Huevos has the same sort of setup -- probably for the same reason :D
regards ---- nelson.b.
