13.0°E HotBird 13C
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Also with osmini4k avl6261 single dvb-s2x tuner
ac1139
120 cm PF, 180 cm offset.
100 km north of Vienna
Metek HDD isn't a receiver, but I have tested it and works. BUT. My VU ZERO 4K is working too. So probably it is NOT in short mode....
Received on a GTCombo rx, CS TBS6903 card, 1.2mtr CM, cheap pll lnb, location North Nottinghamshire-UK.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
All good with Géant OTT 750 4K EVO.
10971 H,29700,2/3,8PSK-New, Services IPTV/Radio Swiss streams, encode Viaccess
EnoSat
enosat.euweb.cz
Slovakia
Which PID is IPTV? Only Video/Audio pids are encoded
I rechecked 10971 H,29700,2/3,8PSK with neumoDVB, under Linux. Fortunately I'm glad I was wrong when I said it was an IPTV stream because I found that it's actually the Swiss package activated yesterday, it seems, with TV and lots of Radio.
Need to check under Windows, and see if it can see it usually. I haven't tried it on this OS yet.
I discovered it yesterday; whether it was before or not is less important, but the fact that it is not IPTV, and this package can be seen and heard on FTA radio, and not as I initially thought.
I also checked on Windows.
EnoSat
enosat.euweb.cz
Slovakia
yesterday you had a huge error rate when transferring from CS (which TSR also showed you),
this transponder for Kabelio has been broadcasting for at least 2 years with minimal changes in the cast
Sorry, but what about "the huge contribution"... rates in your post, Mr. Vigilante.
EnoSat
enosat.euweb.cz
Slovakia
If you want to process the DAB signal on the e2 receiver, use that installation procedure
Satfaca
Melmac (46N, 14.5E)
Melmac
Just a note ... it only works on certain images (mainly old ones), for sure on OpenATV 6.4
Pepeyeb
Eutelsat 5 W B con antena de 1m.
Receptor de satélite Octagon SF 8008 twin. Dreambox Two.
Toledo (España)
