2 trps on Astra 2A or Eut 28A?
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
It could be a data transmission like the ones on 12129V and 12441V, but I don't have the equipment to check at the moment.
I have also spotted interference signals near 11141/11152/11172: And some weird in 10952. Maybe overloading effect for LNB, and from upperband. But these frequences do not quite add up to high band frequencys.
Now attributed to Eutelsat 28A:
http://www.flysat.com/28east.php
It's 2F PE beam I believe. Look at the following, but remember there will be slight differences because one is low band and the other is high band but for me the similarity is too much to ignore. I'm going to track a transponder on Eutelsat and see how that beam maps throughout the day.
Also I think 11604 and 11681 may be attributed wrong and that they are on Astra 2E PE. Compare them with 11836, 11914, & 11934.
Pietclock
125cm
SE Germany 50°N/11°E
No, that's not possible.... both use too high symbolrates for a 26MHz transponder, and SES satellites only can do 33MHz between 11.7-12.5 GHz. So they really are on E28A. But that new one is 22.000 so most likely is on either 2E or 2F Westeuro beam.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
S/Q
11580 -70/63
11604 -74/63
11681 -74/65
11836 -79/60
11914 -74/60
11934 -74/60
12522 -66/23
BTW, here's my data. If you want to add any transponders that might be helpful to fingerprint off I'll be happy to add them.
S/Q
11580 -70/63
11604 -74/63
11681 -74/65
11836 -79/60
11914 -74/60
11934 -74/60
12522 -66/23
This is helpful because it gives us a snapshot but not the same as tracking the fingerprint over a 24 hour period.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Great idea Huevos, but I assume you mean 11604V not 11640V on the new graph above.
I've also noticed, that all these new transmissions so far in this band all fall within a couple of MHz of the Astra transponder setup.
Yes, must be a typo.
Ok, here's 24 hours data from 11604. Still not convinced? Did they really close 11450-11700 on Eutelsat just to start using it a couple of months later?
One thing is certain, 11580 & 11604 are not on the same satellite.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
S/Q
11580 -70/63
11604 -74/63
11681 -74/65
11836 -79/60
11914 -74/60
11934 -74/60
12522 -66/23
today 4:30 utc
11580 -74/63
11604 -88/63
11681 -79/65
11836 -88/60
11914 -79/55 (2E)
11934 -79/60
12522 -70/33 (2F)
Any other reports from around Europe comparing 11604 against 11836, 11914 & 11934.
The 11580 H frequency has jumped to 11585 H.
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Astra frequency grid ...
Grid frequency would be 11582.25 MHz to be exact, so what you mean?
Now it's 2.5 MHz too high, before it was 2.5 MHz too low.
I've never seen such jumps within a fully used 26 MHz transponder.
C0re
Ede
VU+ Solo SE
My mistake, my apologie.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
today 20:00 utc ( cloudy)
11580 -74/73 (stronger than before)
11604 -79/63
11681 -74/65
11836 -79/55
11914 -74/55 (2E)
11934 -74/55
12522 -70/23 (2F)
