3.7m Prime Focus Prodelin project: any ideas?
3virgul14
Non-Activated User
2.4m Famaval motorised+Tbs6903+Prof8000+ TM 5502HD
Now has a working Prodellin 3.7m! 30W to 62E ! 20db average signal.
Next : 100.5 E asiasat
Dodecanese
You have been busy.
What have they started building next door ?
Hey Maestro. How have you been?
I think they want to have an attic/ terrace with the view. But it will take forever to finish :)
Busy as always,
You will need to change your avatar :D
With regards to the mount upgrades, did you modify/add the metalwork without dismantling the front end ?
Is the main bolt and base plate adapted with a bearing for the elevation, or are the tolerances good enough ?
