zorrin
Specialised contributor
- Nov 12, 2008
- Age
- 51
- Location
- France
- Website
- www.facebook.com
- france
Hi everybody,
i just thinking about this kind of installation.
This is just an idéa and already some problems turn in my mind.
First, some of you will say that a polar mount can do the job...
Ok but this is just more exciting i think, no ?
As you can see the idea is to use normal DiSEqC signal from any receiver to move a dish using 2 actuators plugged to diseqc to 36v positioner and a H to H DiSEqC motor for the polarisation.
Every DiSEqC to 36v positioner are sold with a remote to configure them.
the deal is to configure for the satellite position #1 the elevation on one positioner and the azimut one the second one and the same for the polarisation.
When the receiver send the DiSEqC signal for #1, everyone drives to the programed position.
1st solved probleme, for the polarisation just switch off the two positioners let you configure it with the receiver.
2nd probleme, if used with a normal polar mount we stored satellite from a side to other side in the right order, in this case for the elevation the position stored will go up and then will go down after the 0°.
Is it possible ?
3rd probleme, the loss of Db added by every positioner and the motor...
Every help will be appreciated !
Is it possible ?
