46E (Azerspace 1)
pride21
Sandown Isle of Wight
Azerspace 002.jpg Azerspace 004.jpg Azerspace 005.jpg Azerspace 006.jpg Azerspace 007.jpg Azerspace 009.jpg Azerspace 011.jpg Azerspace 012.jpg Azerspace 013.jpg hi all i changed over to ku band thought i would give Azerspace a go heavy cloud and light rain at times so i did not expect a lot,11015H got ten channels at 95% quality,11134H fourteen channels,tried asia beam on 10974H.
Ive relocated the 46E lnb from the battered old 80cm dish on the tyre to an offset on the 1.1m Triax aligned onto 55E. Quite a big improvement on the Euro beam channels :)
Piltdownpaul
No.1 Spike Milligan Fan
pride21
hi piltdownpaul do you get any signal on the asian beam
Piltdownpaul
pride21
hi all nice clear evening last night 10974H went up to 57% quality tried to see if i could get any other transponder on the asian beam i got 11039V at 56% quality.
Piltdownpaul
The gibertini's doing its job then,nice work.
pride21
hi piltdownpaul it seems so when i got it from supersatellite store it did not have the right fitting for the lnb so i made up a couple of aly strips then bolted the lnb holder to it,the focus seems further away from the boom than i thought it would be but the signal seems stronger in that position.
Piltdownpaul
Well if it works that well, i'd leave well alone!
Dari1 on 11014H is showing a drama in English - and no subtitles!
ELTR has just disappeared from 11014H whilst I was watching it!- lets hope its just a temporary problem
Evening edit - its back again :)
All channels on 11134H have vanished, although the carrier is still on :(
pride21
did a scan on that AG but no channels i wonder if they are gone from there
Piltdownpaul
This is indeed the case,they rescan back in but blank screens....
Anyone in the UK still getting the 2 Euro beam freqs? Im getting zip for the second day running :(
A blind scan hasnt picked them up either :-doh
Or has my lnb moved as Im getting zip off 45E as well!
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
both still ok here A.S.
hairybadger
Bricoleur
46.1N 6.4E
see sig
You mean 11134 again? Is OK for me (eastern France).
Cheers lads - in that case the dish/lnb needs attention, but not tonight as the rain has arrived!
