51.5E Belintersat 1
Various reports that Belintersat has 11220H 27500 is active on the Euro beam. Nothing here atm - anyone getting anything?
It's a spurious (unintended) reception by 51.5°E, of the uplink intended for 52.0°E, 10720 H.
Note the 500 MHz difference.
So although on European beam, it's hard lo lock because it includes noise received by the transponder. I can't lock it, others with bigger dishes can.
mar-val
Slovakia,Zilina
I agree with hvdh. TP is exactly the same as 10720H from 52E.
Signal is weak .
MCelliotG
Thessaloniki, Greece
I have about 7db on 11246H (which is quite low considering I am inside the beam), and no signal on 11220H.
puteez
Octagon SF4008- 90e-0.8w
Ukraine
Belarus24 on fta -11220 Н 1968, dvbs2 qpsk mpeg2, 4/5
and radio Belarus24
No channel id when I scanned it in ?
88cm mesh dish + TM5302HD.
pontiend
Contibruter
south yorkshire
I see it at 9.2dB.
DVBDream scans the channels but no signal.
TBS6983 100cm Dish.
MCelliotG
Signal flanctuating a bit between 8.5 and 9.5db, seems my tuner struggles a little to handle the QPSK combination with the low SR and unusual FEC, but still stable picture!
11220 H 27500 is still underneath, deteriorating the signal quite a lot.
Earlier today Belarus24 was on 11253 H with much better signal.
aceb
Prof Tuner 7301 /
Sussex
Fine here in Dream, scans in as Belarus 24 and Radio Belarus 24. TSreader shows an extra character before the B.
blademedia
Sky
I get it as CH-1 on set top box
Edit, its scanned in ok now
pontiend
Contibruter
south yorkshire
Working fine here now.I needed to reset device in DVBDream.It gets a bit stroppy sometimes.:)
TBS6983 100cm Dish.
s/r 1980 now
Yes they did this the last time this transponder was active change the symbol rate about 5 times then switched the transponder off.o_O
mar-val
Slovakia,Zilina
2 freq. with Belarus TVon atm.
puteez
Ukraine
????? 11220Н 27500 left ?????
@puteez , as I said on Dec 29 (see above), 11220 H 27500 was *unintended* signal via Belintersat (51.5°E).
Same content is still there on 10720 H 27500 of TurkmenAlem (52.0°E).
pontiend
Contibruter
south yorkshire
Also getting Belarus 24 on.
11252 H 1981 4/5 this morning.
TBS69834 100cm Dish.
