55E (Yamal 402)
Lyngsat reports some channels on the *southern* beam - 11045 V, SR 40000(!) 2/3. Can't "see" the satellite so can't check...
Russian beam wipes away the signal (if any) of that Southern beam that covers sub-sahara Africa.
Maybe Spain has a chance?
Retired human
Eh? There's no frequency reuse here and should be very strong anywhere in Europe.
I'll have a look. When it stops raining........ Its lashing it down here atm :(
Retired human
What I meant was there is nothing else broadcasting on that frequency on any other beams.
Also, I cannot see a mention of 3-in-1 beam separation. Thought it was just one single beam split into three, so, in theory, that frequency should be available on all 3 sections..., right?
There is plenty signals between 10950 and 11200 MHz from Yamal-402, just not of the broadcasting type.
Flysat shows more of such signal than Lyngsat.
There is even more proprietary stuff going on that doesn't even lock on a TBS 6925.
Again it's really 3 separate footprints on that map.
Gazprom chose to conveniently use one map since they don't overlap.
http://www.gazprom-spacesystems.ru/en/infrastructure/space/yamal_402/coverage_zones/
Retired human
Gotcha. Does look that way!
To make the picture complete, on the Gazprom link it says:
"There is a possibility of interbeam connection of Southern beam with Russian and European, and Northern beam with steerable beam."
But not used right now, it seems.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Nothing from down here CJ
BlindFaith
TBS 5925
There's a new wideband carrier on 10845V, DVB-S, 30000, 3/4. No useful signal yet, only ts_packets filled with 0xff. Some receivers won't see anything cos the transport error indicator (TEI) is set with 0xff only ;) Here reception is poor, only 4,5dB SNR with clear sky :(
But the MPLP-mux on 12694V, DVB-S2, 15284, 8PSK, 3/4 comes error free with 9dB :)
Good find, don't recall seeing any of the 6 Russian beam transponders below 10950 MHz before!
Comes with over 6,3 dB S/N now, that's even a little better than 11265 V 30000 3/4.
adonis1
There is also signal at 11156V 22000
Yes I can barely lock it, it's ACM/VCM with AOL services in it, uninteresting!
It must have been already in the Crazyscan I posted above, but now this cold an clear evening it locks.
Retired human
Martin are you getting 11265?
Archived-1
Persona non grata
uk
Getting good signals from the multi stream, I am going to have to sort my pci card out :).
Archived-1
Persona non grata
uk
I am quite sure this 5 channel mux is coming from here please correct me if I am wrong, It's very weak and the pictures coming and going,
12522 V 27500
Yes it is Martin - nice catch - I barely got a sniff of a signal off that frequency here using the 1.1m.
BTW the 0's after the names are the timeshift from Moscow (NTV +0 hours etc)
