55E (Yamal 402)
Tururu
Assembled with recycled parts
Recycled as the owner.
Actualmente solo un tp activo (Madrid, Spain): 10976H27500
El resto son de datos medidos en el analizador de espectro (frecuencias en LyngSat).
Fotos de 4 canales del tp activo.
Currently only an active tp (Madrid, Spain): 10976H27500
The remaining data are measured on the spectrum analyzer (frequency LyngSat).
Photos of 4 channels active tp.
Tururu
Servicios en 10976H27500 services.
mar-val
Slovakia,Zilina
Bingo Boom 1-8 on 11345 V 30000 3/4 DVB-S2/8PSK/MPEG-4
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
what signal is everyone getting on 10976h as im strugging to get this its coming and going all the time !!
ps im running this on a 80cm dish and a inverto black ultra single 0.2db lnb
SI 90% SQ up to 71%
Offset lnb on a 1.1m dish aimed at 46E
parkiepie420
sounds like i may need to upgrade to at least 90cm or 1m ??
Probably although Ive always had decent results off 80cm dishes over the years, getting things I probably shouldnt get.
parkiepie420
thanks for the reply analoguesat im going to check the lnb as in moving it up and down the holder see if there is a difference !!
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
Down here in York, on my less sensitive TBS 8920 I'm getting SL 98& and SQ of 71% on a 1m Orbital dish directly pointed at 55E.
pontiend
Contibruter
south yorkshire
I get 10976H 27500. at 69% on my TD88.
the 100 cm cannot see 55E.
TM5402HD TD88 Dish.
I do find the signal jumps up and down a lot on 55E - but its only just above a wooded hill across the valley
parkiepie420
im using a technomate 5402 mk2 and a 80cm dish and im getting roughly 43% and the signal is jumping up and down i think it could be catching the edge of the roof tops of the houses across from me !!
im going to have another go at it tonight providing the weather is ok !!
parkiepie420
hi guys just an update managed to get a better signal on 10976h its now peaking at 57% the dish just needed tweaking a bit !!
thanks again for all your help !!
Retired human
12640V signal disappeared
12602V has a new SR of 16008 and a much stronger signal than before (11dB on the 90cm here).
Tony Daly
1.2mt motorised dish
South West Ireland
Hi Everyone.
New to all of this having been away from Sat for a long time.
South West Ireland with one foot in the ocean.
Don't know whether this is good or not but will throw it in anyway.
12612V SR16083.
Peterburg 5 Kanal.
Zvezda.
Life News.
Rossia 24.
NTV.
Here's a couple of photos, not great as taken with my phone.
12610V must have moved to the European beam :)
Its a huge signal here even with a massively offset lnb
Retired human
Definitely not European as people in the middle of Russia are receiving it, where the European beam doesn't reach.
There's confusion to the frequency - it's actually 12604V but can be locked I think about 10MHz either side due to TP width... And I get a higher signal using SR of 16008 - reported elsewhere.. But yes, a strong signal nevertheless!
Good grief they must have REALLY turned the power up in that case - Im getti9ng 63% atm with an 11 degree offset lnb!
Before:
12603 V 28975
12639 V 14913
Now there's only:
12603 V 16084
No wonder it's so strong now, all power of the 72 MHz physical transponder 12620 V is now on 12603 V.
