5E SES-5
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
First TV from 5E ?
3715L 1300SR unknown channel from africa
aceb
Prof Tuner 7301 /
Sussex
Kveys
Southern Finland
Retired human
Thank you for this. Getting 7dB here - another satellite logged, though I have completely run out of satellite positions on my F15 :(
Does Technomate 5402 M1 offer more than 64 slots?
pride21
Sandown Isle of Wight
hi CJ the 5402 mk 1 has the same sat positions that's why I brought the F15 so that I would use that for c-band and the 5402 for Ku-band,the only gripe with the F15 is that I could not fix a larger size cable to it only 1mm cable goes in.
Retired human
Hm OK. I do have a pretty unused F15 back at my parents... unused because there's a massive tree growing in front of the Fibo dish, so it's more or less useless. But then, the remotes will clash...
pride21
I have tha main cable going in the 5402 then out into the F15 I have to turn one receiver off each time I want to pick either c-band or ku-band
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
A new TV station called R2 TV Nigeria is now on. Parameters are as follows: 3868 RHCP, SR 1203, FEC 5/6, QPSK
Reception report by PEON
satosk
Also RAVE TV that is on 3714 LHCP has changed FEC from 1/2 to 5/6.
satosk
Parameters are as follows: 3868 RHCP, SR 1203, FEC 5/6, 8PSK
I just want to mention that I made a mistake that unfortunately can`t be edited. It is QPSK, not as I wrote 8PSK.
Archive-8
Just got rave tv to scan in :-) in gib 1.25 it's around 5db according to my Dr HD.
Archive-8
[SATTYPE]
1=0048
2=C-Band
3=3
4=0
5=5150
6=0
[DVB]
0=4
1=3691,H,1299,56,5
2=3837,H,1439,14,133
3=3902,H,46990,34,132
4=4049,H,46990,?,20
Archive-8
[SATTYPE]
1=0049
2= Astra 4A / SES-5
3=3
4=0
5=5150
6=0
[DVB]
0=3
1=3691,H,1299,56,21,|-48 dBm, 7.9 dB
2=3837,H,1439,34,148,|-48 dBm, 1.1 dB
3=4049,H,46990,?,4,|-43 dBm, 5.2 dB
pride21
hi chris it seems rave tv has gone there is not a glimmer of signal
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin + SF8008 SUPREME + Uclan Ustym 4K PRO Twin
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Rave is back on.
Thanks for that C.
Had a scan this afternoon.........Rave still there:-
Overall scan gave this.......but WOW, look at that SR of 61977 :eek:
CrazyScan gave a slightly different result:-
Rushed now, back later.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Scan this morning.
Finally locked the frequency I wanted on this sat, EBSpro would not scan it in but the Technomate 5402 did.
3868 R 1203 R2TV Nigeria http://www.royalrootstv.com/
¿Beat the clock.....some here would remember this then?
