fcs001fcs
Newbie to the Dream
- May 30, 2005
- Age
- 92
- 3 LNB 80CM Dish, (Hotbird, Astra 1 & 2) DM800, DM7020S & DM500S, PLi® Beta
- BENELUX
Hi All, I have a 7020 that seems to be insensitive to certain select frequencies.
For example, it works fine for Sly (legal card), German FTA and Premiere but NASN in Premiere Star is at 70% or less (clear day low BER, cloudy day no picture). Also ORF channels are similarly affected. Other frequencies are also affected but I have not spent the time to list which ones.
I have another 7020 and 2 500s that are connected to the same dish and LNBs (13, 19, 28) through DiSEqC switches and they all work fine for the frequencies concerned.
I have switched the problem 7020 to a 500 working connection and it is the same; this would seem to eliminate the connection (cable, DiSEqC, LNBs) and indicate that the 7020 box itself was the problem.
I then ordered and replaced the Philips Tuner on the main board hoping it was a bad tuner but I have exactly the same issue.
The working 7020 and problem 7020 have same setup, image, emus etc... .
Is there anything else I should check or replace (except the main board totally) that may fix this problem?
Any and all suggestions would be appreciated.
Thanks, FCS
Thanks, FCS
