Vipersan
Emmett Browns Ghost
- Jun 29, 2009
- Age
- 66
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
nelson_b said:hi -
thanks for the reply --
before i assembled the petals on mine i -- i made a flat platform with 3 by 2 inch batons and 3/4 in plywood -- and built it face down on that -- with all the bolts on the petals finger tight -- then tightened the bolts a little at a time round and round in a sequence until they were all done up -- so as not to pull it out of shape --
i noticed that all the petal bolts are almost a perfect fit for the holes leaving no slack for adjustment of the petals -- i,m pretty confident that i,ve got it near right
from the very good k/u results i got from it once i had the feed and l.n.b sorted .
i think i will send off for a BSC421 as i would like to test the alcoa to its limits on C band and if it proves to be good - it would be nice to make a polar mount and motorise it .
A project for next year - i think
as i,v just turned 60 i,m intending to reduce my work to part time from the end of this year --
cheers nelson.b.
Hi Nelson ..
Sounds to me that your Alcoa will be pretty much optimised already ;)
As for the BSC421..
I doubt you will be disappointed ..
..it pulls in fringe channels that the pauxis misses ...
..at least thats what I found.
Just a pity that it costs as much to ship as it does to buy..
the scalar plate it comes with is good ...but for truely excellent results you may want to fit your 3 ring 'deep' valley plate from your corrotor..
Im conviced there are less than 6 transponders unreceivable now at 55 ..west ...and these western H/Vbirds are where most of the action and fun is ..
If for example you find you can get the Brazillian or possibly Mexican transponder
4099 H
tp 26 XHTVL Canal 9 DVB-S2 2272-3/4
QPSK
Hemi
XHTVL Canal 9 MPEG-4 4131 4129 Sp
XHTVL Canal 9
...Then you know you are truely getting the max ..
Sadly this and a few others are still eluding me..
rgds
VS
