- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
You are aware that the feed centre point has to be on the central line of the reflector, boresight and for full efficiency you have to ensure the feed is perfectly aligned with the perpendicular axis of the reflector surface, no margin for error.Hi All,
I just wanted to give a quick update on how I have been progressing. I have straightened the dish using the structure shown in photo 1 & 2. I had split the dish into 12 segments using fishing line and then used the threaded bar to ease the dish into shape so that all the lines just touched in the centre. I have centred the Invacom feedhorn on the axis of the dish and set it to the calculated focal point and I have maxed out the signal as far as possible using alignment and adjusting the lnb (including skew). I have been maximising it using the SD transponder in image 4. I haven't as yet hooked up the HD machine- but I wouldn't be that confident as I had been hoping to push a higher reading on the above TP.
One questing I have relates to the Invacom adjustable Feedhorn. I did the calculations for the projection required and accurately set it using Vernier callipers. On Saturday, as an experiment, I tried adjusting the corrugated feedhorn as I though it would need 'tuned'. I tried it at half turn intervals. And you know what?- It made zip difference!! I tried the ring right along the threaded section and the signal strength and quality stayed exactly the same. I even tried the ring projecting a few threads beyond the waveguide and again it made no difference. Next I tried the corrugated ring completely off (just leaving the waveguide). In this instance the signal strength stayed the same but the quality dropped by 4%. Does this seem right? I admittedly don’t fully understand the purpose of the corrugated ring but I would have thought that it should have had more of an impact than this- especially as the projection is supposed to be important. Am I missing something?
Thanks Trev
Additionally the screw in/out part of those feeds has to mimic the focal point of the dish, so alignment is done with extending the feed arms to the optimum distance and then adjusting the scalar by turning the thread. It does take a number of small adjustments to get right, especiially with a feed arm system like yours that has three reflector bolt holes that require synchrony in where they need to be tightened.
In cases like this, I would conclude that if you have done the above as best you can and without firm measurements with an analyser, the reflector is sending received signals everywhere, both to the feedhorn but also elsewhere and no matter how many adjustments you might make, the dish parabola will not perform any better than you currently get without distorting it.
It could be you have a defective or 'second' manufacture dish or feedhorn but only a proper check with the right equipment is going to give you an answer.
Where did you get it and how was it advertised ?
