- Oct 12, 2003
- See Signature
- Somewhere in England (possibly?)!
My centauri 16/1 is on the end of 25-30m of WF100 cable (+ up to 8m of cables to the LNBs themselves) and there's also a Smart Priority Switch (and an antenna relay in the case of the SX88+ in the Lounge!) in the path and that combo works fine.According to the datasheet, the centauri has larger loss: 5dB vs. 3dB and is much more expensive.
I have 3 centauris. They work fine, even in combination with a long cable. up the Because they are big,
it is also easy to attach and detach cables.
However, this Vyzion switch does not seem very practical for outdoor use with cables on all 4 sides.
Or do I miss something?
The only downside is that the F-sockets on the switch are quite close together and that makes it quite difficult to tighten up the plugs and then seal them - so I use a small 11mm open-ended spanner with the sides ground down, and then coat all the connectors with a spray-on rubberised sealant (much easier and remove than trying to fit self-amalgamating tape or rubber boots) before I slide the switch into the cover.
