Amos 7 (was Asiasat 8) 4W
dreamsat
germany
11047 H 5000 2/3 8PSK
dreamsat
germany
today is verry good reception at Amos
A slightly stronger signal from the MiddleEast spot now
@dreamsat, please check if the symbol rate has changed to 11039 H,500,2/3(data), now I found at 11041 H of 250,1/4
11061 H,4500,2/3 and 11541 H,3701,3/4
dreamsat
germany
i confirm this, the 11039 is at a moment not received
Good reception of the Amos 7 CEE beam in East Anglia today. Neumodvb default spectrum covering a section of the horizontal high band, plus a zoomed spectrum showing some marker TP details generally hidden in the spectrum scan.
Plus a mosaic of the channels occupying 12340H. Ignore Romania TV on the bottom -that's 12354H.
Gibby 1.2M dish, Inverto KaKU LNBF.
A quick check on Amos 7 again, this with the latest neumodvb version 0.8.
Not much more locking than before, but marked TPs show data now without panning down.
(12583H is 5W)
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Latest scan ( 10.95 - 11.2 )
Satfaca
Melmac (46N, 14.5E)
Melmac
11.541 H - stongest ever on my location. More than 2dB more than normal. You might want to check your luck...
11053 H,500,1/4,S2,ACM-Generic stream,new
As I said on another occasion, late evening is the best time to receive the signal from the Middle East spot, at least in my area.
dreamsat
germany
new is 11070 H 3702 QPSK 3/4 is a duble from 11541 H
So far, I've only picked up the signal at 11069 H. I hope to see the content soon.
I also hope it will be as strong as at 11541 H, which will probably leave; I don't know when.
For now, both frequencies are working at the same time. I don't think 11069 H is directed to any other area than the Middle East.
Satfaca
Melmac (46N, 14.5E)
Melmac
11.541 H recently got weaker some 2db-3dB while simultanously/contrary 11.070 H gained some 3dB-4dB. I haven't been able to receive later before, now no problem.
pitussat
dishes: CM 3m SMC,-Prodelin 3m SMC old version ,CM 1,80m SMC, Fibo 1,2m, Wavefrontier T90
receivers;>30 different types.+ TBS5925/6925 ETC
belluno, Italy
hi everyone, my lock for 11048H8 ( 10-10,6 dB ), 11062H ( 9-10,5 dB ) ,11069 H (7,5-9,5 dB ),11543H ( 7-11,6 dB 9 and 11474V( 5,8-6,5d:cool: from NE ITALY 3m CM
Satfaca
Melmac (46N, 14.5E)
Melmac
After 11.541 H has been switched off, I can now finally receive 11.047 H as well with 2.4m
dreamsat
germany
my scan vertically there was sometimes more
11081 H,2000,1/4
Maybe someone will try to determine if this mux has a media stream. Some parameters tell us that it might be such a stream.
Being fringe capture, I'm unsure if the recorded file is helpful to the analysis.
EnoSat
enosat.euweb.cz
Slovakia
occasional requests for certificates from
Microsoft Azure TLS Issuing CA 010
221207220108Z
231202220108Z
dreamsat
germany
my scan
anto@
italy
today
