Anyone tried to make BIG dish at home?
mouse3
1.2 offset,1.2 simetric ,0.9 offset.
Transilvania
For Dx-ing each fraction of dB counts.Ferrite-magnetic polarizer add more noise,are not good for DX-ing.Mechanical skew are the best,i want to make one like in the picture below,but for primefocus dish.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I am also looking for Rotary Actuator. Who has an idea where to get one like on picture or similar?
JanH
Dreambox 800
Czech rep.
True. For end of all pipes from all dishes (-: must be something like that.
I mean fine adjustment before pipes connected together. I think feritte inside polarizer just shape magnetic field becouse it could not do something on microwave directly. Something like static magnet. For small adjustment may be enaught magnetic field from outside of pipe only without ferrite. It could be easy experiment to try - magnet for example from loudspeaker and pull on to pipe. I would like to check it bat for me experiments on roof are not so popular in this time.
mouse3
Transilvania
I found samthing,but nobody here talk about experiments or performance...
Sounds intresting,to add more surface to LNC probes...using one pcc 12 GHz antenna inside the feedhorn.
Increasing the probes surface,increasing the gain...wright or wrong ?
This antenna are from 8 to 20mm long perfect for SHF range.
Magnetic field and microwave,this combination need more experiments in the future...the strongest magnets are use inside the CD-rom,each desktop have this items inside....two cut in half of the circle.
Trust
Nijmegen Netherlands
A dutch member (wimpie) of Fibo-owners builds them
There is also german shop selling such thing RT-467 for € 850.-
The pics showing my own projects , instead of the lnb , i skewed the 150 cm PF dish
RimaNTSS
N-E from Riga
Trust1! Interesting project! Skewing PF dish is basically same as you skew LNB, only difference is that more weight added to construction. How do you point your dish to satellites? Is that polar-mounted?
Trust
Rimantss , I don't have that setup anymore but it was a 2 axis EGIS rotor , capable for up to 300 cm dishes . It was easier to find and steer that heavy stuff than that fine mechanic for rotating the lnb .
Later I build me a 30 cm off-set "Crazy Dish" (google) and a Echostar 120 cm off-set project is on the way .
Both have a motor rotator on the elevation axle .
mouse3
Transilvania
One more picture about this subject...:)
RimaNTSS
N-E from Riga
Mouse3! Could you please post more pictures of your antenna taken from different positions? How do you control all those actuators?
Trust
Nice job , as well the counterweight and the lnb-selector .
My experience is , with a counterweight , less motor noise .
On my first set-up , i also have a lnb selector , Ku/ Dbs lnb .
Because my analog Anderson receiver didn't receive the upper part of the KU band , therefore i used the DBS lnb .
mouse3
Transilvania
It s not my antenna,i have this picture on my database...
JanH
Dreambox 800
Czech rep.
QUOTE]
I am not shure if I understud. You mean reflector in focus point pointed to LNB or pipe in midle of dish?
I think it depend on how energy is focused in focal point of the dish. If the energy area is bigger than feedhorn it should be better with reflector. When you collect by subreflector too big area then you collect signal as well as noise from "empty" area.
Probes surface should be same as dish energy focus pattern.
Subreflector gives you some lostes too.
Other point of view - for used dish f/d should be specific feedhorn design which collect maximum energy.
JH
JanH
Dreambox 800
Czech rep.
Doas anybody know what is best f/d for todays ordinary LNB?
JH
mouse3
Transilvania
Here ar the picture about,pcb antenna for GHz.I want to install this small pcb antenna inside the feedhorn and attached to the LNC probes,do you understand now ?
JanH
Dreambox 800
Czech rep.
Yes :-)
Quite new wind in this forum. I am curious about it.
I try to find some ideas on internet. There ar may be usefull links about feeds and dishes:
_http://www.w1ghz.org/antbook/conf/Multiple_reflector_antennas.pdf
_http://www.qsl.net/n1bwt/chap5.pdf
In same time I find something about ofset antenas design. It for me main thema now. I will try to resolve "Universal LNB" feedhorn parameters, for what antennas are suitable ( in fact ).
JH
franksanderdo
2m PFA
Invacom TWFH031
DM800HD S
AZBox Premium S
Mac Book Pro
Saudi Arabia East Coast
JH
Hi JanH
usually those ordinary LNB have a f/d of approx. 0.6 to 0.65 depending on the manufacturer
I hope this helps?
Best wishes for the new year ;-)
Frank
JanH
Dreambox 800
Czech rep.
Thank you Frank,
looks designed for offset dishes (not surprising). Round older parabolic dishes have usually about 0.35 and new universal LNB is not too convenient for it. I would like check my offset dishes for f/d if it is right, but roof is with snow now :-)
Happy New Year!
mouse3
Transilvania
It s a bit late,sorry,Happy New Year,Guys :-ohcrap
JanH
Dreambox 800
Czech rep.
What is f/D parameter of yours big dishes?
I think it is very important for feedhorn design.
JH
JanH
Dreambox 800
Czech rep.
Somethink may interesting about new feed design.
JH
  • Loop_Feed_DUBUS_Version.pdf
