Arion Af-1700e
salvador
www.studyenglishintheuk.com
Ferguson Digibox & Mini dish - Arion AF-1700EC & 80 cm dish
Computer Setup? a couple of PCs and a few Laptos
Thanks guys.
Well I spoke to my friend last night and he said that he was shown how to enter the codes but he never got round to do it as he couldn't find codes to unblock certain movie channels, so he moved on to another receiver :-( He is certain that you can unblock some channels with the af-1700 E but you just have to find the codes. He sent me an email with links to places that do codes but none of them work.
One thing that I found out is that the Arion is made in Korea but Ferguson makes an identical stb in Poland http://www.telstar.com.pl/index_en.php?id=2&type=a&item=6
Maybe I can find a patch under Ferguson....
I will look for the firmware Termanl AF-1700E and see how can improve my stb.
Thanks again guys.
Salvador
tamazgha2003
dreambox 500s
tamazgha
look here for up to date firm
http://depo.avaralar.biz/index.php?&direction=0&order=&directory=RECEIVER%20FIRMWARE%20EMU/TERMAL
you need to convert the header to make it compatible for arion with
autoarioner
http://laki.dvhk.pl/fredka.htm
salvador
Thanks a lot for the links.
I downloaded the AutoArioner but the other link timed out... perhaps I should try a different time of the day.
I found this link but could not find any firmware there : http://www.ferguson.wz.cz/arion.html
Thanks again.
Salvador
salvador
autoarioner
Hi again.
I managed to download the firmware (AF 1700E FTA POLSAT FIX S170E_$OZK_A6479_20050905_AUCPCnc.auc), I think it's an up to date version - my Turkish is Zero:) I don't know what this firmware improves my stb but I sure like to know.
It seems that AutoArioner converts the header of the firmware file automatially as I don't see any options to convert the header - please confirm.
Can the cable be any 9 pin serial cable (RS-232C) or does it have to be a special pin arrangemet?
While looking for information I came across "Arioner" anoher application software to upload the firmware to the STB. Can you comment on what software is better / more secure to do the uploading of firmware.
Thank you so much for all the help.
Salvador
tamazgha2003
dreambox 500s
tamazgha
hi,
a few explication about autoarioner
you need a nullmodem cable male-female(9 pin subd cable),i think it will do what you have
AutoArioner - dedicated for upgrade firmware in Arion's tuners.
Auto select COM and set required header.
Description:
"File to send" - AUC firmware for tuner
"Scan" - Scan for listening and transmission
STATUS:
GRAY - port not exist
RED - port is busy
PINK - sending data
YELLOW - listening confirmation
GREEN - port ready to use
BLUE - error - close all application and try again
Progress bar:
Blue - load status
Red - estimate flash status
For new tuner use key:74620 in standby for detect header.
1.put your receiver in standby mode
2.start autoarioner
3.chose file to send
4.to detect the header of your receiver use remote control by pressing 74620
then you will see your type,ver,model
if not restart autoarioner again
5.then off and on again the receiver by the rear switch
and wait till shows "upgrade complet"
to active the emu(scrambled chanells):
menu-------19370-------2486
then goto games you will see "edit keys"
regards
salvador
Hey thanks for the info.
This is getting really exiting :) . Need to get a nullmodem cable and then try it out.
Tomorrow I'll try to get a cable if a find one.
Do you think I got he latest firmware from that site?
Regards and thanks again.
Salvador
p.s.
tamazgha2003, I just read your post 15 on this thread http://www.satellites.co.uk/php-bin/forum/showthread.php?t=37819
and I'm now confused. Why am I using only AutoArioner?
Thanks in advance.
tamazgha2003
dreambox 500s
tamazgha
because autoarioner is easy
otherwise you need 2 programme to work with it:
a.you need auc-heditv 095 to change the header (to make it compatible for your receiver)an then save the file
b.you need arioner 0.24 to upload your firmware
look first what bootversion you have if you have boot 16.01 or more then you need only autoarioner
but if you have a bootversion less (older)then 16.01 then you need to upgrade the bootversion with arioner 0.24 and you need allso auc-heditv 095 to convert the bootfile for your receiver
salvador
Hi tamazgha2003,
Great point, I'm glad I asked before I went ahead.
The infor for my stb is:
The SW version is $SPHA333SS170EC
Database version is 00600009
Boot version is 0011.1
So, I downloaded the two peograms you mentioned AUC_HEditv095.exe and Arioner024_PL.exe
The $64000 question is: Where do I find a boot version that is newer than 16.1? Most of the places you get these firmware from, are either in Turkish, Polish or Russian and I don't understand a word of those languages. Although I can get Russian translated, but for the other two I always get a feeling that I don't know I have the correct file ;)
I have done a fair amount of reading on the matter and it seems that people that get into trouble with upgrading their stb do not take enough precautions. Could you comment on any DO NOTs and DOs and the safest way to go about upgrading a stb? Can you back up your firmware before loading up the new file?
You mentioned something regarding games and changing keys in one of your posts. It might be a silly question but am I getting new games with a newer firmware? I'm not into games really, I just want to view more channels in Spanish or English from the hotbird satellite. My friend can watch some film channels with his new stb and I quite like that, I think he gets multivision channels, if that means anyhing to you!
Can I just thank you again for taking the trouble to educate me on this subject, I truly appreciate your kindness.
Salvador
tamazgha2003
dreambox 500s
tamazgha
now i m confused ist arion AF-1700E or AF-1700EC
for arion AF-1700E u can use bootfile 16.1
http://depo.avaralar.biz/index.php?action=downloadfile&filename=TERMAL S170E_OZK_A5272_BUCPCn.zip&directory=RECEIVER FIRMWARE EMU/TERMAL/BUC DOSYALARI&
to use AUC_HEditv094 chose in "convert to: detect instead of AF1700"
and follow the instruction(dont forget by :"correction" chose boot)
salvador
O-Ha
I just double checked the sw version ....S170EC and it's correct!
I didn't realse that it was ...170EC, good job that you spotted it :)
I tried the link that you gave me but it tells me that either the site is unavailable or the site does not exist. I'll have to try later on again and see if I get lucky :)
I downloaded AUC_HEditv095 as opposed to AUC_HEditv094. I don't think this would make much difference, would it?
I'll post here when I try the site again.
Thanks a lot.
Salvador
tamazgha2003
dreambox 500s
tamazgha
this link will do
enter buc dosyalari and you will see the file
salvador
I tried the link above again but no luck :(
I followed the other link and downloaded the file TERMAL S170E_OZK_A5272_BUCPCn.zip
I couldn't find a RS232 cable today but this weekend I should be able to get hold of one. However, I opened the file with AUC_HEditv095 and I noticed that there wasn't any AUC info but since this is an .BUC file perhaps it is expected.
Do you know what's the difference between an AUC and a BUC file?
Slowly but getting there :-bighappy
Thanks for the link.
Salvador
salvador
OK, I got myself a nullmodem rs232c female to female cable. I hope this is the right cable... is there a way I could test it?
Before I do anything, is it possible to backup the current firmware?
What should I expect after uploading the new firmware? Will my channel selection and preferences be removed?
Later on today I will try to do the first part of the process, using the header editor. I'll report back with results :-)
Thanks in advance.
Salvador
tamazgha2003
dreambox 500s
tamazgha
auc.file=firmware
buc.file=boot
nullmodem rs232c female to female cable=good cable
u can use ariter2 to keep your channels preference and this is how it work:
To use Ariter2, please follow steps as below
I. Receiving Data from Receiver to PC
1. connect PC and Receiver with RS232c cable
2. Turn off power and keep the receiver in standby
3. Press Blue Arrow button on Ariter program
4. Then, press “74621” on Remote Control to the receiver
5, It starts receiving data from the receiver to PC
6. After completing receiving the data, it is opened
II. Sending Data from PC to Receiver
1. Connect PC and Receiver with RS232c cable
2. Turn off power and keep the receiver in stand-by mode
3. Press Red Arrow button on Ariter program when it opens Data file
4. Then, press "24680" on Remote Control to the receiver
5. It starts sending Data to the receiver
u can use AUC_HEditv094 or AUC_HEditv095 to back up your firmware
salvador
Hey man, you are wealth of knowledge :-)
Thank you so much for all the info, I really appreciate it.
Unfortunatelly, my wife was watching a program so I couldn't get to the stb, I'll see how I get on today.
I downloaded Ariter2 and Ariter18 which looks a little better but I don't kmow if it is good for the job.
Can I ask what kind of channels you get access to after you patch the stb?
I'll keep you posted.
Salvador
salvador
Just getting down to back up my channels / firmware, etc. This might be a silly question but do I need to unplug the stb from the TV and satellite dish or it makes no difference?
Thanks.
Salvador
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I can see no advantage in doing either :cool: although in theory it would not make the slightest difference.
salvador
So........ I don't unplug them, do I?
Salvador
salvador
tamazgha2003 said:
this link will do
Hey,
I just came across this boot file http://www.zotos.biz/download.html
S170EC_$STM_A6579_20050906_AUCPCnc.zip. It seems to be newer that the Turkish one. What do you think? Does it make any difference?
Salvador
tamazgha2003
dreambox 500s
tamazgha
i m with toppervte33h,it make no difference
afther patching you get MORE channels thats all
