Aston Cam 103
Billo
Bedfordshire
Hi guis
I got an aston 1.05 is it good as the 1.03?
Ca you tel wich card is to use knot or opos for sky ?
tanks
roberto mafara
Pace 2600C1 DM800HD Vu+Duo
Laminas ofc 1200 triax 1100
Black ultra lnb
BenissaCosta Costablanca
Billo said:
Hi guis
tanks
Wellit depends what opos osyou have if is1.02 forget it better off with knot :chc
Billo
Bedfordshire
Hi Rob I dont have any at the moment but if you say that the knot is better then I will go for that ( is even half of the price of the opos)
ps can you tel me on how to program one, and were to get the file or better wich file to look for
many thanks
Comunque ciao a presto.
roberto mafara
Black ultra lnb
many sat forums in english tell you how to program a knot card justsearch in Google .
Buon Natale :ch2
Billo
Bedfordshire
Buon Natale :ch2
thanks I'll try the search on google but what about the codes wich one do I need
roberto mafara
Black ultra lnb
Search in Google for knot S*ca 2 files and you will find them;
I have opos but need to change it for 1.03 at moment it freezes now and again or today there where files for titancard2 for S*ca2 :ch1
comunque buona fortuna Ciao
Billo
Bedfordshire
wait a minute Rob I have the blu tit card can I reuse that do you think?
ps I must been rud Buon Natale anche a te
roberto mafara
Black ultra lnb
Not for Se*a but i dont know if wltdo files will work on aston cam
ill try now and let you konw ina sec :)
roberto mafara
Black ultra lnb
No it does not you need a Mr cam
Billo
Bedfordshire
ups Rob I think I wont probabily stick with the knot card and try to use the aston 105 with it.
bay the way I just find same soft ware on the cafetera web site for the knot card I gues I gonig to ceck that out
but say what about keep in tauch since we have this hobby in common maiby we can exchange information in italian by e-mail
roberto mafara
Black ultra lnb
ok my email is robi62*tiscali.es :chthumb
