Astra 1N at 19.2E
The Sky transponders change is imminent. On the night of this Tuesday to Wednesday, it will be ready. The pay-TV providers will convert between 23.45 and 4.30 clock its satellite at the orbital position Astra 19.2 degrees East from DVB-S to the more efficient DVB-S2 standard, and this change the corresponding transponder.
11.141 H SR 22.000 DVB-S2 new tp test
over night tp sky germany switch
  • 1540-15_Web_PDF_Transponderumstellung.pdf
after two year hd again change transponder today 10803h sr 22000 fec 2/3 dvbs2 8psk and 11464h sr-22000 fec 2/3 dvbs2 8psk
10862h 22000 2/3 8PSK DVB-S2
SKY DE 4K
New CanalSat in February 2016
It's Tuesday, February 9 will take place the next "service plan" bouquet of Canalsat and with it its share of novelties.
11567.50MHz, pol.V SR:22000 FEC:2/3
Sundance Channel
Campagnes TV
12090.00MHz, pol.V SR:29700 FEC:5/6
BFM Business
11895.00MHz, pol.V SR:29700 FEC:5/6
BFM TV
12402.00MHz, pol.V SR:27500 FEC:3/4
Offer free programs in high definition (HDTV). German regional programme SR Fernsehen (Saarländischer Rundfunk) started tests in HD resolution.
On satellite, Astra 1 l in the multiplex ARD Digital discovered technical test SR Fernsehen HD. In the same muxu are FTA programs Eins Plus Eins Festival HD, HD and Tagesschau 24 HD electronic programming guide in (EPG) SR Fernsehen HD is given information that the 17.2.2016 will take place at this position the test broadcast and then kick off a test operation here SR Fernsehen.
SR Fernsehen (Saarländischer Rundfunk) will be another program in HD resolution, which puts candidates in the FTA HD at 19.2 ° E. German tv ARD plans this year to expand the menu and run programs ARD and Radio Bremen Alpha HD TV HD. Writes DigitalFernsehen. These stations are not yet propagated only in MPEG-2/SD.
technical parameters-forthcoming HD version:
satellite: Astra 1 l (19.2 ° E)
rate: 11.053 GHz
polarization: horizontal
SR: 22000
FEC: 2/3
standard: DVB-S2
8PSK modulation:
SR Fernsehen HD
service ID: 10378
video PID: 5431 (MPEG-4/HD)
Audio PIDy: 5432, 5433 (German) (original), 5436 (AC3)
CA: no, FTA
A Dutch platform of CanalDigitaal withdraws from the Astra (19.2 ° E) distribution of the SD version of the main Dutch Canalthat public and private broadcasters. In the future, the channels will only be available in HD on satellite Astra 3B (23.5 ° E).
RTL 7 and Net5 will be the first SD channels, which will be removed from the 19.2 ° E. This will happen on March 22 of this year Then on May 5, a similar fate befall NPO 3 and RTL 5. No dates have not yet been designated for NPO, 1 NPO, 2, RTL 4 and SBS6, but it will happen by the end of 2016. At the same time CanalDigitaal using Mediaguard 2 coding system will end.
Four other channels-RTL 8, Veronica, SBS9 and RTL-are now available only in HD from the satellite Astra (23.5 ° E).
Subscribers CanalDigitaal who have older satellite receivers and/or card option is offered, Mediaguard 2 code alternative.
February 11, on the Astra 1 l satellite discovered the technical test stations SR Fernsehen HD. Initially aired here test the shape and from 17. February is possible on SR Fernsehen HD watch normal broadcast stations.
about the tests, which will take place for a few months. Sound broadcasting will run up to 1. July 2016.
SR Fernsehen is a regional station of the Saarländischen Rundfunks (SR) for the Saarland in Germany. The station was so far only available in SD resolution and FTA.
During the test period, the program airs just in time from 16:00 to 22:00 hours. In the remaining time of the program is upkonvertován in HD.
SR Fernsehen HD broadcasts the same program as SR Fernsehen. Different technical quality of image and sound.
technical parameters-SR Fernsehen HD:
• Astra 1 l (19.2 ° E) freq 11.053 GHz, pol. H, SR 22000, FEC 2/3, DVB-S2/8PSK, FTA
technical parameters-SR Fernsehen SD:
• Astra 1 m (19.2 ° E) freq 12.266 GHz, pol. H, SR 27500, FEC 3/4, DVB-S/QPSK, FTA
- TF1 12402v
- France 2 11856v, France 3 11856v, France 4 12402v, France 5 12402v, France ? 12402v
- Canal+ 11856v
- Arte 12402v
- M6 12402v
- BFMTV, iT?l? 11856v
- D8 12402v, D17 12402v , 11856v
- Gulli 12402v
- NT1, TMC 11856v
- W9 12402v
- NRJ 12 11856v
- Canal+ Cin?ma 11856v, Canal+ Sport, 11856v Plan?te+ (payantes) 11856v
- La Cha?ne Parlementaire 12402v
- HD1, L'?quipe 21, 6Ter, Num?ro 23 11934v, RMC D?couverte et Ch?rie 25
transponder change next two days of tnt france
before two days football game transmited on astra
Movistar+ 4K el FC Barcelona-Real Madrid
Canal + Partidazo 4K---10729 V DVB-S2/8PSK MPEG-22000 2/3
Astra 1KR @ 19.2° East
The complete Canal Digitaal SD line up is still being transmitted on 19.2E, 12515 H 22000 5/6, PID 0x384. Where SD channels no longer exist the HD channel from 23.5E is being swapped into the list.
tnt france move to dvbs2 on 19.2e
11934v
29700 fec 2/3
dvbs2
german sd left on 19.2e
sat 1 gold 12545h
rtl nitro 12188h
bayeran ferensen 11836h
SWR Fernsehen Baden-W?rttemberg 11836h
channel 21 12148h
dmax 12480v
juvelo 12633h
servus tv 12663h
10713 H,23500,3/4,Dvb-S2/8PSK,HEVC new tp it not look 1m
I got 4.2db with 3.8m
adonis1
12.5 db with 1.5m
Tururu
Assembled with recycled parts
Recycled as the owner.
Moves data currently between 21Mbs. and 24Mbs.
Some pictures of the demos.
PS: Good fishing.
here we got on 4.5m 4,7 no lock
