Astra 1N at 19.2E
astra 2c start move soon to 1n or 1m,1l
Now, My sources at one broadcaster told me that there are moves of TP's from 2C as far as the 18th so if this is true I don't expect 2C to move until the last week of march.
2c play signal
next big move tp
digital plus will be come from 2c to 1n ?
My guess is final 2C transponder unloading on 18th and then on the move by 20th.
Some TP will go from 2C to 1L and others will go from 2C to 1KR but no movement from D+ from 2C to 1N as far as I have been told.
Well D+ will have to migrate soon as 2C is destined for backup duty at 28E.
it good news for ditiatal plus move to 1l and 1kr
better coverage here
The transponder 1,071 (SWR Fernsehen BW) and 1.019 (SWR HD)
Switch on 11.03.2014-20.3.2014 from the satellites 2C or 1L to 1N satellite
The transponder 1,085 (SWR Fernsehen RP)
2C satellite to satellite 1N
I think I may be wrong, 2C centre of box info is still being updated beyond 23rd now. Doesn't look like it's going anywhere in a hurry just yet.
Good morning,
I think 11954 H and 11836 H is now in astra 1N from astra 2C I have reception here
in south Greece CRETE .Before in these 2 transporters I have no signal.
5 tp move last night
11.836h tp 71 ib 2c see on afternoon 1n i see at morning 8.3db
12.110h tp 85 2c -1n 5.db
tp50.10729 2c -1n 8.7db
tp.55 10803h 2c -1n no lock
tp77 11954h 2c -1n lock
tp 117 from 1l move to 1n 12692h 6.5db
tp 115 from 1l move to 1n 12663h 5.9db
From 2C I can confirm only 11.836 and 11954....10729,10803,12110 still ZERO....
10729v and 10803H are both over 14dB with no change from last week here so looks like 2C to me.
Here are my results in Helsinki:
19 - 11.494H - Now 7.5dB - Was 12.7dB on 1L
25 - 11.582H - Now 7.2dB - Was 12.8dB on 1L
71 - 11.836H - Now 7.3dB - Was 13.6dB on 2C
77 - 11.954H - Now 9.1dB - Was 12.6dB on 2C
113 - 12.633H - Now 4.6dB (no lock) - Was 11.9dB on 1L
115 - 12.663H - Now 4.3dB (no lock) - Was 11.8dB on 1L
117 - 12.692H - Now 4.7dB (no lock) - Was 12.4dB on 1L
Other 1N transponders are up by about 0.5dB this morning from last week but could be down to good clear weather here.
Edit: Added in 11.494H above
signal from me
Before and after for the latest changes (11837H and 11954H).
Can confirm signal quality on those transponders has dropped, but still fine. I would start getting pixelating if quality on DVB-S transponders drops below ~22%, ~31% on DVB-S2. Right now Das Erste HD is 45% quality, Das Erste SD 42%. So I still have some signal margin too. Phew (part deux)!!!
