Astra 1N at 19.2E
This morning's moves from 1M Europe to 1N PE in Helsinki, 80cm, DrHD F15 readings on a clear morning:
86 - 12.129V - 9.1dB (was 11.3dB yesterday on 1M Europe)
88 - 12.168V - 8.9dB (was 11.5dB yesterday on 1M Europe)
90 - 12.207V - 9.1dB (was 11.8dB yesterday on 1M Europe)
94 - 12.284V - 9.8dB (was 12.6dB yesterday on 1M Europe)
96 - 12.324V - 10.0dB (was 12.8dB yesterday on 1M Europe)
98 - 12.363V - 9.8dB (was 13.0dB yesterday on 1M Europe)
100 - 12.402V - 9.6dB (was 12.6dB yesterday on 1M Europe)
102 - 12.441V - 8.9dB (was 12.1dB yesterday on 1M Europe)
These new transponders are more forgiving, I can live with these results...
Shame there were no horizontal polarities to test, as they will be weaker for me.
all freuqncy receiver with 3.8m
12129v 7.5db
12168v 7.3db
12207v 7.2db
12245v 7.3db
12324v 8.1db
12363v 7.4db
12402v 6.8db
12441v 7.2db
12521v 7.4db
12552v 6.5db
12580v 7.0db
12640v 6.5db
12670v 7.0db
more signal
A couple of horizontals for you to check here:-
http://www.flysat.com/astra1n.php
also orange move from 1m to astra 1n
12284v
6.7db
I think 11259 V 22000 has just moved from 1L to 1N all the channels went off air then briefly came back free to air now encrypted again.
11436 H 22000 has just done the same found after a full scan of 19.2 east channels showing as not encrypted then re encrypted.
11259 V & 11436 V remains in its place
I would be very interested on the results of northern Finland, Norway and Sweden by Astra 1N..
12129v 7.5db
12168v 7.3db
12207v 7.2db
12245v 7.3db
12324v 8.1db
12363v 7.4db
12402v 6.8db
12441v 7.2db
12521v 7.4db
12552v 6.5db
12580v 7.0db
12640v 6.5db
12670v 7.0db
Not bad. What kind of signal did you get on these channels before?
I was thinking of eventually moving an 85cm Sky (28.2E) dish I have to 19.2E in northern Finland but might not bother now, depends on what finally goes on 1N when it all settles down... Might end up using Hotbird 13E!
Interesting they do this during the day, presumably they are lesser important channels anyway?
They seem to be doing a reshuffle, as per 28E, by moving channels off other Satellites, on to 1N and then replacing the vacated TP's elsewhere with 2C's if I'm correct?
