11728V is within the bandwidth of 11720V and is the same transponder, showing Sky Box office with a set of channels labelled "unknown".Nothing to do with 11739V TP...
Try scanning 11728 V 27500 this freq. not listed on any satellite directories yet, but lock for me and some others.
now signal 1.5 db 11755h
You'll still get a lock either side of the central frequency of 11720.
It's a mistake which we've all made at one time or another.
11758H Astra 2A North Beam ..here 15,3dB..nothing new here..now signal 1.5 db 11755h
So you have almost 30dbuV signal strenght difference (10942 vs 11798) so 10942 could be leaked from the high band frequency. As lnbs may have typical 30db isolation between low/high band. I have this effect, best seen for 11160 that is leaked from high band.A picture is better than 1000 words.
Una imagen mejor que 1000 palabras.
One is on the high side and a low side.So you have almost 30dbuV signal strenght difference (10942 vs 11798) so 10942 could be leaked from the high band frequency. As lnbs may have typical 30db isolation between low/high band. I have this effect, best seen for 11160 that is leaked from high band.
I think when people are looking for "new" transmissions the best thing would be to check this list kindly supplied by a certain member of this forum:
http://www.selkirkshire.demon.co.uk/analoguesat/astra19e_frequency_allocation.html
With the exception of Band A at the moment (still under Eutelsat control), all the other frequencies listed are the ones that will be used by the Astra satellites at 28E too and some will be used by Astra 2E. If you are seeing anything on another frequency you have probably misread something. The transponder numbers might not match up but the frequencies are OK.
here nothing in 12500.can same one make one check on this ?
thanks !!
TP 15 Astra 2A North 11992 H 17dBI had a good transponder lock and constellation diagram on 11980H about 10 minutes ago but it has since vanished.
