Astra 2E: On Hold At 43.5E
Deso
1.2m Generic dish, Sky+ HD and Technomate TM5402 HD box.
Fuerteventura/UK
skomedal
This and that
thule
Once it completes its temporary mission at 31.5E.
Wow the plot thickens :D
My understanding is that Astrium have control of this bird until it gets to its final intended position ( presumably 28.2E ) where SES take over and do their testing proceedure before lighting up and going live.
WHO has it when @31.5E????????????
trevortronix
Sky+ Pace 3100 JTAG (FTV)
Technomate TM7102HD-T2 Super
MTI 0.3dB quattro on 1.4m Prime Focus
Inverto Ultra on 1.1m DiSeqC motor
Tavira, Algarve, Portugal
31.5E? Where did that come from?
Pietclock
125cm
SE Germany 50°N/11°E
motivated by those Scans of Llew I gave it a try with an old Icom radioscanner, which can receive 0.5 - 2450MHz. I fed in the IF with a splitter from the LNB, and it really worked for the 12493 MHz beacon. I can "hear" it using narrow FM, it sounds a bit like those computers in old Bond movies seerp seerp :D
It goes silent when I move the dish... so it has to be it. That's great, so I can follow it as well.
Excellent work Pietclock :D
Can you also receive the 11707.50V beacon with your rig?
The carrier amplitude is very low at my locality on both 2E beacons. Presumably as the footprint moves west my signal will increase.
Archived-1
Persona non grata
uk
I have been following this thread with interest and amazement with your knowledge, I do have a scanner but not sure what freq range it has, ive not used it for years. is this an hard task to learn please, any links would be great for me to have a read up on if anyone has any to hand thanks in advance for any help.
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
I didn't know that the 1L and 1KR may have some troubles. How do you know?
M60
Northern England
SES have already confirmed via facebook that it's heading for 28.2E in Feb - unless you've a different source and a change of mission has been sought with the non-arrival of 5B?
If your receiver ranges up to at least 2 GHz or so, you can try as Pietclock has done, i.e take an output from your LNB.
The frequency to search for is 12493MHz - the LNB LO frequency (10600) = 1893MHz.
hexah
Hadrians Wall
Great stuff.
I assume you have connected the scanner to the splitter output that does not pass power or it could go pop.
I know the outputs are meant to be isolated but some scanners had very sensitive input stages, lightning and static arrestors were essential.
C0re
Ede
VU+ Solo SE
But how do you dertermine a satellite has a problem of some sort? Can you read some data of the satellite or just by measuring the signal strength?
Pietclock
125cm
Just tried 11707.5 .... I get something there as well, but it sounds differently, it's a long feeeep sound, while on 12493 it's pulsating. Definitly different kinds of signals.
They are quite weak, although I am using a 125cm dish.
I also tried it on 19.2 east, I get something as well there, but not as "definite". I think the strong wide carriers there are too much for the radioscanner, and it cannot filter the weak narrow beacons out.
@hexah: yeah I used an Axing SVE2, it has diode protection.
hexah
Hadrians Wall
Pietclock
125cm
http://sat-nd.com/failures/index.html?http://sat-nd.com/failures/a2100arrays.html
1L and 1KR are A2100 models as well...
So: http://www.ses.com/10260492/17_02_2012_FY2011-d
Page 6 of that it states:
Probleme mit der Funktionsfähigkeit von Satelliten
In der Satellitenflotte von SES gibt es derzeit elf Satelliten des Modells Lockheed Martin
A2100, bei deren Sonnenkollektoren es zu Anomalien kommen kann. Im Zuge einer strikten
Risikobegrenzungsplanung, einschließlich beschleunigter Ersatzbeschaffung, konnte die
potenzielle Auswirkung von Ausfällen im Großteil der Flotte deutlich verringert werden.
Translates: Problems with the functionality of satellites.
In the satellite fleet of SES there are currently eleven satellites of the model Lockheed Martin A2100, whose sun collectors can be subject to anomalies. In course of a strict risk containment planning, including accelerated replacement aquisition, potential effects of failures could be reduced in a large part of the fleet.
C0re
Ede
VU+ Solo SE
Thanks for the explanation!
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
If I had My H/P Spectrum Analyzer working, I would have had a real go from the beginning at 2E but unfortunately it has developed some Errors about a year ago especially in the r/f section and being a laboratory equipment it will be too expensive to send to the factory for refurbishment.
This unit can handle from 30c/s to 26Ghz. Specially made for Satellite work.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
1H is now stable
M60
Northern England
Ni
Nice analyser, I've got a HP Agilent 8590, covers L Band up to 1.8GHz, use for my terrestrial broadcast work.
Waveguide
Dish and box
North
I found some non DVB-S signals to test some ancient test equipment on.
At 5E low band vertical something is transmitting pulses at different intervals.
11050 MHz is one frequency but there are others too. My big dish is fixed so
I can't track 2E but some day it will be motorised so why not test the rest of
the equipment now.
The main part is a panoramic receiver, 1 - 18 GHz. Not very good on sensitivity
and selectivity but robust. A splitter on the LNB-connection, a DC-block and
a preamp gives a useful readout but it's all analog so you have to calculate
frequency and span yourself. Setting sweep width to zero makes it a fast
signal strength meter so amplitude modulation can be detected.
Hopefully I can get the smell of the bacon when 2E comes close to 28,x E.
11050 MHz 5E low band vertical
28,4E low band vertical
